  3. SKILL pPar error during CDF parameter handling
  • Views 16342
AleksandrV
AleksandrV over 9 years ago
Hi all,
I'm trying to pass parameters from the top level schematic to a lower level schematic.
The schematic and CDF parameters are generated without problems, but when I try to modify the value of existing schematic components (in this case only inductor is present) and insert pPar("__CDFparName__"), I get an error which says that pPar is an undefined function. Both schematic and symbol are created using dbOpenCellViewByType. The procedure is presented below:
procedure( pcellTestProc(LIB_NAME CELL_NAME VIEW_NAME )
 let((params cellId cdfId cvSchem)
    cvSchem = dbOpenCellViewByType(LIB_NAME CELL_NAME "schematic" "schematic" "w")
    dbReopen(cvSchem "a")
    unless( cellId = ddGetObj( LIB_NAME CELL_NAME )
        error( "Could not get cell %s." CELL_NAME )
        when( cdfId = cdfGetBaseCellCDF( cellId )
        cdfDeleteCDF( cdfId )
    ; insert inductor "ind" from library "analogLib"
    params = insertInstance(LIB_NAME CELL_NAME VIEW_NAME "analogLib" "ind" "symbol" "Lpkg" 1 0:0 1:0 "R90")
    cdfId = cdfCreateBaseCellCDF( cellId )
    ; Parameters for the
    cdfCreateParam( cdfId
        ?name "extParamL"
        ?prompt "inductance"
        ?defValue ""
        ?type "string"
        ?display ""
        ?parseAsCEL "yes"
    cdfSaveCDF( cdfId )
   ; change  value
    params~>l = pPar("model") ;<------------------------ HERE'S WHERE I GET AN ERROR: *Error* eval: undefined function - pPar
    dbSave(cvSchem)
    dbClose(cvSchem)
 );let
);procedure
How are pPar values passed on to the exiting component parameters via SKILL, where did I go wrong with my approach?
Aleksandr
  • skillUser
    skillUser over 9 years ago
    Hi Aleksandr,
    The property type is a string, so the pPar call needs to be formatted as a string (you don't want to try and call a SKILL function named pPar() now, it is to be evaluated later, e.g. during netlisting):
      params~>l = "pPar(\"model\")"
    Hopefully this will resolve the issue?
    Best regards,
    Lawrence.
  • AleksandrV
    Hi Lawrence,
    Thanks for the lightning response.
    Yes, that fixed the issue. Thanks!
    Aleksandr
