  3. simple skill widgets and dbLayerAnd()
  • Views 16161
MalcolmWhite
MalcolmWhite over 9 years ago
I discovered that it's pretty easy to make interconnections on shapes of wires , especially for example , grids of power wires , when they are part of a list of shapes.
So I make two lists, one of the lower level metal , the other the upper layer, I then "dblayerAnd()" them together with the format of (cv "vialayer" list1 list2)
but my problem is the vialayer parameter produces mostly rectangles where the AND is satisfied , I then have to use another program to transfer the
resultant rectangles centerBox into the xy coords of an actual via instance - isn't there a way to shortcut this ?  Would I instead of using "vialayer"
make something like dbLayerAnd(cv dbCreateVia(cv techGetTechFile(viaID) centerBox(andArea) "R0" ) ??
thanks.
    No, you can't do that. You could potentially use dbPointArrayAnd instead as this avoids having to actually create the temporary shapes, although because the result is a list of point lists, you have to do a bit more work to find the centres of the resulting regions.
  • MalcolmWhite
    thank you Andrew.
