  3. Getting the time point in the calculation
  • Replies 8
  • Views 23735
liorscotland
liorscotland over 9 years ago
hello all.
I am looking to create a waveform. How do I use the x point value as a point?
I.e.:
wave(time) = average( VT(net1) time )
    I don't understand your question. Can you explain this in a bit more detail? What do you mean, how do you use the x point value as a point? I don't know what your "i.e." means - average doesn't take a second positional argument.
  • liorscotland
    Sorry, wave(time ) = average( clip (waveform) nil time) )
    So, the time acts as input to the clip, and "forces" a wave context.
    Maybe a mapcar procedure is needed here, and generate a new empty waveform?
    Hi Lior,
    Sorry, I still don't understand what you mean. You already can give time arguments to the clip function, so I just don't get what you're asking for?
  • liorscotland
    Yes, but how do you get the average to output a time-dependent average waveform, and not a scalar?
  • liorscotland
    i.e. I want to see a waveform that would be: for each X value, the Y value would be, for example, the average of VF("/net1") from the leftmost X point until the X value. So, in the leftmost X axis value, the value of waveform will be, in fact, just the value of VF( "/net" ). So, average needs to be sampled in every X axis point, and collected to a new waveform.
    Thanks. That's clear now.
    What  you want is (assuming your signal is in a variable called signal):
    iinteg(signal)/xval(signal)
    This assumes that the signal starts at X=0. If not, you could use the abFirstX function defined in this COS article and use:
    iinteg(signal)/(xval(signal)-abFirstX(signal))
    or if you had the signal not in a variable:
    iinteg(VT("/OUT"))/(xval(VT("/OUTM")-abFirstX(VT("/OUTM")))
    The normal average is defined as the definite integral (integ) divided by the difference between the last and first X point; in this case we just use the indefinite integral (iinteg) and divide by the difference between the current X point and the first X point (for each point).
  • liorscotland
    Thanks.
    But don't you get a divide by 0, when xval(signal) == abFirstX(signal)) )?
    Should it not be:
    iinteg( VT("/OUT" ) )/ if( xval(V("/OUTM") > abFirstX( "/OUTM" ) (VT("/OUTM") - abFirstX(VT("/OUTM")) 1 )
    I was a bit lazy. It worked because the first value ends up being NaN (actually -nan) and so doesn't get plotted. What you could do is:
    procedure(CCFcumulativeAverage(sig)
      let((new)
        new=iinteg(sig)/(xval(sig)-abFirstX(sig))
        drSetElem(drGetWaveformYVec(new) 0 abFirstY(sig))
        new
    I have not attempted to set the units, axis names, expression etc on the waveform object - this is just to show the principle of how it could be done (the above should work though). You can't use your conditional approach because it's going to be comparing the wrong types of object. Also, you asked for the first value of the output to be the first value of the input waveform - this function will now do that.
