  3. SKILL pCell STREAM OUT failure
  • Views 15802
DannyRitt
DannyRitt over 9 years ago
A pCell fails during stream out stage.
(unsupported XStream function in Pcell SKILL)
All functions behaves normal during testing and are taken from previous Cadence development. The pCell also fails manual stream out procedure.
Thanks for your help...
Danny
procedure(CCScreateBoxAndLabels(cv w l lay)
  let( (rectRodObj)
  ;; create a rectangle on metal1 with x & y dimensions set by w & l
  rectRodObj = rodCreateRect(
      ?name     "myRect"
      ?cvId     cv
      ?layer    lay ; list("Metal1" "drawing")
      ?width    w
      ?length   l
      ?origin   list(0 0)
  ;; create labels to show the w and l parameters
  dbCreateLabel(cv list("text" "drawing") list(0 0)
    sprintf(nil "%2.8f" w) "lowerLeft" "R0" "stick" 0.05)
  dbCreateLabel(cv list("text" "drawing") list(0 0.2)
    sprintf(nil "%2.8f" l) "lowerLeft" "R0" "stick" 0.05)
  ;; create a stretch handle for the width, in the X dimension, it
  ;; will display as "width = <value>" and change by 0.1 increments
  rodAssignHandleToParameter(
    ?parameter          "w"
    ?rodObj             rectRodObj
    ?handleName         "centerRight"
    ?stretchDir         "X"
    ?displayName        "width"
    ?displayExpression  "w"
    ?updateIncrement    0.1
  ); rodAssignHandleToParameter
  ); let
); procedure CCScreateBoxAndLabels
procedure(createDRBox(cv w l lay objName orig)
  let( (rectRodObj)
      ?name     objName
      ?cvId     cv
      ?layer    lay
      ?width    M1w
      ?length   M1l
      ?origin   orig
    ?parameter          "w"
    ?rodObj             rectRodObj
    ?stretchDir         "X"
  ); let
); procedure
procedure(placeContactsNP(Width Length)
prog( (i j)
i=0
j=0.060
x=1.070
y=1.070
; Bottom Part
; First Row
while( x < Width-1.070
dbCreateRect(cv list("CO" "drawing") list((x:y) (x+j:y+j)))
x=x+0.185
) ;while
; Second Row
x=1.370
y=1.370
while( x < Width-1.370
x=x+0.185
) ;while
; Third Row
x=1.670
y=1.670
while( x < Width-1.670
x=x+0.185
) ;while
; Fourth Row
x=1.970
y=1.970
while( x < Width-1.970
x=x+0.185
) ;while
; Fifth Row
x=2.270
y=2.270
while( x < Width-2.270
x=x+0.185
) ;while
; Top Part
; First Row
x=1.255
y=l-1.070
while( x < Width-1.255
dbCreateRect(cv list("CO" "drawing") list((x:y) (x-j:y-j)))
x=x+0.185
) ;while
; Second Row
x=1.555
y=l-1.370
while( x < Width-1.555
x=x+0.185
) ;while
; Third Row
x=1.855
y=l-1.670
while( x < Width-1.855
x=x+0.185
) ;while
; Fourth Row
x=2.155
y=l-1.970
while( x < Width-2.155
x=x+0.185
) ;while
; Fifth Row
x=2.455
y=l-2.270
while( x < Width-2.455
x=x+0.185
) ;while
; Left Part
; First Row
x=1.070
y=1.255
while( y < Length-1.255
y=y+0.185
) ;while
; Second Row
x=1.370
y=1.550
while( y < Length-1.550
y=y+0.185
) ;while
; Third Row
x=1.670
y=1.855
while( y < Length-1.855
y=y+0.185
) ;while
; Fourth Row
x=1.970
y=2.155
while( y < Length-2.155
y=y+0.185
) ;while
; Fifth Row
x=2.270
y=2.455
while( y < Length-2.455
y=y+0.185
) ;while
;  Right Part
; First Row
x=w-1.070
y=1.312
while( y < Length-1.312
y=y+0.185
) ;while
; Second Row
x=w-1.370
y=1.610
while( y < Length-1.610
y=y+0.185
) ;while
; Third Row
x=w-1.670
y=1.915
while( y < Length-1.915
y=y+0.185
) ;while
; Fourth Row
x=w-1.970
y=2.215
while( y < Length-2.215
y=y+0.185
) ;while
; Fifth Row
x=w-2.270
y=2.515
while( y < Length-2.515
y=y+0.185
) ;while
) ;prog
);proc
procedure(placeContactsPP(Width Length)
prog( (i j)
i=0
j=0.060
x=-1.325
y=-1.325
; Bottom Part
; First Row
while( x < Width+1.380
x=x+0.185
) ;while
; Second Row
x=-1.325
y=-1.165
x=x+0.185
) ;while
; Top Part
; First Row
x=-1.325
y=l+1.105
x=x+0.185
) ;while
; Second Row
x=-1.325
y=l+1.265
x=x+0.185
) ;while
; Left Part
; First Row
x=-1.325
y=-.950
while( y < Length+0.950
y=y+0.185
) ;while
; Second Row
x=-1.165
y=-.950
y=y+0.185
) ;while
;  Right Part
; First Row
x=w+1.105
y=-0.950
y=y+0.185
) ;while
; Second Row
x=w+1.265
y=-0.950
y=y+0.185
) ;while
) ;prog
);proc
;; Create the PCell, the "drawing routine"
pcDefinePCell(
  list(ddGetObj("testLibDR") "isolationRing" "layout")
    (w 10.0)
    (l 10.0)
;    (Hl 5.0)
;    (Hw 5.0)
;    (He 1.0)
  let( ((cv pcCellView))
    ; Create the FLASH
    dbCreateRect(cv list("FLASH" "drawing") list((0:0) (w:3.4)))
    ; Create the DNW over the FLASH
    dbCreateRect(cv list("DNW" "drawing") list((0:0) (w:l)))
    ; NP Isolation Ring
    ; NP Layer
    dbCreateRect(cv list("NP" "drawing") list((0.760:0.760) (w-0.760:2.640)))
    ; Create the Contacts for the NP Ring
    placeContactsNP(w l)
    ; PP Isolation Ring
    ; PP Layer
    dbCreateRect(cv list("PP" "drawing") list((-1.43:-1.43) (w+1.43:-1)))
    placeContactsPP(w l)
  ); let
;; Create the CDF for the 'l' and 'w' parameters, the width (w)
;; parameter is either hidden or displayed but not editable.
let( (cellId cdfId)
  when(cellId = ddGetObj("testLibDR" "isolationRing")
    ;; if the cell CDF already exists, delete it
    when( cdfId = cdfGetBaseCellCDF(cellId)
      cdfDeleteCDF(cdfId)
    ;; create the base cell CDF
    cdfId = cdfCreateBaseCellCDF(cellId)
    ;; create the parameters
    ;; BM Layer
    cdfCreateParam( cdfId
      ?name     "l"
      ?prompt   "Ring Length"
      ?defValue 10.0
      ?type     "float"
      ?display  "t"
      ?name     "w"
      ?prompt   "Ring Width"
      ?defValue 10.0
      ?type     "float"
      ;; comment out the next line and uncomment the lines below
      ;; it if the parameter is to be visible but not editable
      ?display "t"
;      ?editable        "nil"
    cdfSaveCDF(cdfId)
  ); when
); let for CDF creation
    This is because when you create a PCell, it only stores the code in the body of the pcDefinePCell() in the pcell layout cellView. Any auxiliary function that you call is not stored. Your code is calling placeContactsNP and placeContactsPP and when you stream out (unless you pick the stream out from VM option) won't be known by the separate stream out process. Similarly if you exited virtuoso and started again, it would have the same problem unless you loaded the code again, which would recreate the PCell - which would mean  you have to have write access to the PCell each time you loaded the code.
    In general you should either separate the code which creates the PCell (and CDF) from the functions called within it. Here's how I made your code work properly with stream out:
    1. Right before the line pcDefinePCell( I added another line:
      procedure(myCreatePCell()
    2. Then at the very end of the file (after the "); let for CDF creation") I added another close parenthesis by adding a line:
    3. This means that now the creation parts are separated from the functions used within the PCell.
    4. Now add a file called "libInit.il" in the library directory for testLibDR and in this file add:
      load("/path/to/the/code.il")
    5. This libInit.il is loaded the first time anything accesses that library, either in the stream out program or in Virtuoso, so that means all the relevant functions will be defined.
    6. In the CIW, also load the code.il file and then call myCreatePCell()
    All should then work correctly if you do this.
  • DannyRitt
    Many Thanks Andrew.
    Your suggestion worked very well.
    Danny
