  3. Layer Cyclic Field within a PCell
  • Views 15532
GirishRK
GirishRK over 9 years ago
I'd like to know if PCells are capable of integrating layerCyclicFields within them. I know individual layer and purpose cyclicFields can be integrated using cdfCreateParam(). I am looking for an elegant solution where I don't need to check for the existence of a layerPurpose pair in skill. My current flow is -
1. Use tech~>layers~>name to generate the layers list.
2. Execute a callback when the required layer is chosen to generate the correct purpose list by using techGetLP() to check for validity of the LPP.
3. Generate a cyclic field for the purpose names using the above generated purpose list.
Thank you,
Girish
    A few bits of terminology here:
    1. PCells don't have user-interface functions as part of them - that wouldn't be valid in the PCell code itself.
    2. CDF doesn't supper layer cyclic fields as a field (or rather parameter) type.
    You'd either have to write your own form for editing the properties of the PCell which has a layer cyclic field, or use a standard type (string, cyclic or radio) of CDF parameter.
