  3. problem with pcell with radio button
  • Subscribers 147
  • Views 16291
techrddyz
techrddyz over 9 years ago
Hi all,
i am trying to make a PCELL using SKILL script. I want my PCELL to be able to turn on/off certain layers based on the radio button selected by users. In the following code, I draw m1, m2 and m3. If user selects uptoM1, only M1 should be on, and if user selects uptoM3, all M1, M2 and M3 should be on. I have a call back function, decap_metallevel() in the radio button CDF to turn on and off metal layers.
However, this function doesnt turn on/off metal layers when i select different radio button. Does anyone see where the problem is??
pcDefinePCell(list(ddGetObj("testbench") "decap_pcell_test_1_SKILL" "layout")
    ((uptoM1 boolean "TRUE")
(uptoM2 boolean "TRUE")
(uptoM3 boolean "TRUE")
    let((uptoM1 uptoM2 uptoM3 pcMember pcStretchGroup
   stretchOffsetX stretchOffsetY pcLib pcMaster pcInst
   pcTerm pcPin pcPinName pcNet pcTermNet
   pcNetName pcTermNetName pcMosaicInst pcParameters pcParamProp
   pcStep pcStepX pcStepY pcRepeat pcRepeatX
   pcRepeatY pcIndexX pcIndexY pcLayer pcPurpose
   pcLabelText pcLabelHeight pcPropText pcParamText pcCoords
   pcPathWidth pcPolygonMargin
(pcLib = (pcCellView~>lib))
(pcParameters = ((pcCellView~>parameters)~>value))
(pcParamProp = car(exists(prop pcParameters
   ((prop~>name) == "uptoM1")
(uptoM1 = (pcParamProp~>value))
if(((pcParamProp~>valueType) == "boolean")
   (uptoM1 = (uptoM1 == "TRUE"))
   ((prop~>name) == "uptoM2")
(uptoM2 = (pcParamProp~>value))
   (uptoM2 = (uptoM2 == "TRUE"))
   ((prop~>name) == "uptoM3")
(uptoM3 = (pcParamProp~>value))
   (uptoM3 = (uptoM3 == "TRUE"))
if(uptoM1 then
   (pcLayer = 12)
   (pcPurpose = "drawing")
   (pcInst = dbCreatePath(pcCellView
   list(pcLayer pcPurpose)
   list((0.209:0.705)
(1.963:0.705)
   ) 0.2 "truncateExtend"
if(uptoM2 then
   (pcLayer = 15)
   list((0.999:1.429)
(0.999:0.185)
if(uptoM3 then
   (pcLayer = 18)
   list((0.344:0.988)
(1.922:0.988)
t
;select or unselect all based on SelectAll
procedure(decap_metallevel()
case( cdfgData->MetalLevel->value
( "uptoM1t"
 cdfgData->uptoM1->value = "true"
 cdfgData->uptoM2->value = "nil"
 cdfgData->uptoM3->value = "nil"
( "uptoM2t"
 cdfgData->uptoM2->value = "true"
( "uptoM3t"
 cdfgData->uptoM3->value = "true"
);case
;; Create the CDF
let( (cellId cdfId)
  when(cellId = ddGetObj("testbench" "decap_pcell_test_1_SKILL")
    ;; if the cell CDF already exists, delete it
    when( cdfId = cdfGetBaseCellCDF(cellId)
      cdfDeleteCDF(cdfId)
    ;; create the base cell CDF
    cdfId = cdfCreateBaseCellCDF(cellId)
    ;; create the parameters
     cdfCreateParam( cdfId
      ?name    "uptoM1"
      ?prompt  "uptoM1"
      ?defValue    "true"
      ?type    "boolean"
      ?display    "nil"
      ?name    "uptoM2"
      ?prompt  "uptoM2"
      ?defValue    "true"
      ?type    "boolean"
      ?display    "nil"
      ?name    "uptoM3"
      ?prompt  "uptoM3"
      ?defValue    "true"
      ?type    "boolean"
      ?display    "nil"
      ?name    "MetalLevel"
      ?type    "radio"
      ?prompt  "MetalLevel"
      ?defValue    "uptoM1t"
      ?choices list("uptoM1t" "uptoM2t" "uptoM3t")
      ?display "t"
      ?callback  "decap_metallevel()"
    cdfSaveCDF(cdfId)
  ); when
); let
Rudy
    Rudy,
    Your callback function was wrong. It's setting the boolean parameters to "true" and "nil" (I've no idea why). It should set them to t/nil as follows:
      ( "uptoM1t"
       cdfgData->uptoM1->value = t
       cdfgData->uptoM2->value = nil
       cdfgData->uptoM3->value = nil
      ( "uptoM2t"
       cdfgData->uptoM2->value = t
      ( "uptoM3t"
       cdfgData->uptoM3->value = t
     );case
    With that, it works fine.
