  3. How to select shapes overlapped by a text or label ?
  • Subscribers 148
  • Views 16690
Marben
Marben over 9 years ago
Hi All,
How to select shapes such as rectangle in the layout that is overlapped by a label name "vref_1 " or "vref_2" or" vref_3" ?,
by using SKILL and rexMatchp ?
Best regards,
Marben
    I'd probably use pcre functions, but the principle is similar (you only need to use the rex functions if using IC5141):
    cv=geGetEditCellView()
    labelPat=pcreCompile("^vref_[123]$")
    foreach(shape cv~>shapes
      when(shape~>objType=="label" && pcreExecute(labelPat shape~>theLabel) ; could use rexMatchp here instead
        shapesUnderneath=dbGetTrueOverlaps(cv list(shape~>xy shape~>xy) t 0)
        foreach(under shapesUnderneath
          unless(under~>objType=="label"
            geSelectFig(under)
    Note the code above is completely untested - this is just to give you an idea.
  • Marben
    The code works exactly as I want it.
    You're a genius.
    Thank you very much.
    Best regards,
    Marben
