  3. how to cut an array of rectangles in a big rectangle?
  • Views 15856
kentlintu
kentlintu over 9 years ago
Hi All,
I am a newbie to SKILL programming and need help on the following question that seems simple yet getting me stuck for a while. Any help will be appreciated!!
What I am trying to do is simple: I would like to cut several repeated rectangle holes in a rectangle. I have no idea how select the bunch of squares at once and generate the wanted rectangle with holes.
; create the big rectangle
bigrectangle = dbCreateRect(pcCellView mylayer list(0:0 10:5))
; create the array of rectangles
for(i 1 10
xxx = dbCreateRect(pcCellView mylayer list(i*2:4 i*2+1:6)) ;<----------------------------------?? don't know how to  select the rectangle array at once and then eventually delete it after layer generation
layerAndNot( pcCellView mylayer list(bigrectangle) list(xxx))
dbDeleteObject(bigrectangle) dbDeleteObject(xxx)
    Something like this should work:
    smallRectList=nil
    for(i 1 10
      smallRectList=cons(
        smallRectList
    dbLayerAndNot( pcCellView mylayer list(bigrectangle) smallRectList)
    foreach(smallRect smallRectList
      dbDeleteObject(smallRect)
  • kentlintu
    Thanks very much, Andrew!!
