  3. Toggle schematic instance, wires, and pins selectable
  • Views 14915
psill000
psill000 over 9 years ago
Is there an env varaible for toggling instances, wires, and pins selectable in a schematic?
Paul
    Paul,
    Try this:
    /* abToggleSelectFilter.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 07, 2017
    Modified
    By
    Toggle the schematic selection filter settings.
    Call:
    abToggleSelectFilter("instance")
    abToggleSelectFilter("wire")
    abToggleSelectFilter("pin")
    etc.
    SCCS Info: @(#) abToggleSelectFilter.il 04/07/17.22:03:53 1.1
    procedure(abToggleSelectFilter(option)
        let((current)
            current=schGetEnv("schematicSelectFilter")
            current=foreach(mapcan opt current
                if(opt=="allSchObj" then
                    list("label" "pin" "pinName" "marker" "noteShape" "noteText"
                        "flight" "wireName" "wire" "instance")
                else
                    list(opt)
            schSetEnv("schematicSelectFilter"
                if(member(option current) then
                    remove(option current)
                else
                    cons(option current)
