  3. Virtuoso XL Auto Router(routing width input ?)
  • Views 5569
Amar Kumar
Amar Kumar over 9 years ago
Hi All,
I am using Auto Router option(Virtusos XL -> Route -> Automatic Routing) for the layout routings.However the tool is routing by taking the minimum width of the metal layers.
Is there any way to customize the routing width of each metal layer in Auto Router tool?
I tried searching the option for specifying width input in the Auto Router GUI ,but i could not find it.I have little idea that the width can be controlled by creating a customized "constraint group".But not very clear about this.
Please suggest me some way to do it(I am using Cadence 6.1.6 version).
Thanks In Advance,
Amar
  • francktellier
    francktellier over 9 years ago
    I Amar,
    I think you can customize the width of each metal in the "wire assistant" .
    To open the wire assistant click on : Window -> Assistants -> Wire Assistant
    Then you can change the width of each metal, the routing direction, the via etc etc ...
    Regards
  • Amar Kumar
    Hi Franck,
    Thanks for your reply !!!
    Even I am changing the width of Metal layer in "Wire assistant",the "Auto Router" tool taking the minimum width of each metal layer.
    Do I need to save it after doing the customization? If yes ,as it saving as a "constraint group",how to access it in Auto Router ?
    Amar
  • Cristina Ibane
    Cristina Ibane over 9 years ago
    Hey Amar!
    There are some steps that you need to follow:
    1. Edit your width/ spacing in Wire Assistant.
    2. Click on "Configure Wire Assistant"
    3. Click on "Save Option Value" and when the window opens, set the path and click "Save"
    4. Whenever you lose the settings you could go to "Restore Option Value" and read from the saved file.
    Hope this works!
