  3. Questions about ADE-XL results menus
  • Views 15503
LuisGutierrez
LuisGutierrez over 9 years ago
Hi all,
Virtuoso version IC6.1.6.500.13.2
I have a couple of questions regarding ADE-XL menus:
1. Is is possible to modify the order of the tools in the output setup such that the "add new output" and "delete selected output" are far from each other? Several times I have deleted by mistake expressions that took a while to build and in general it is a good practice to separate controls that do the opposite things. Alternatively.. is there a way to undo the delete action?
2. How to organize expressions belonging to a particular test after initial setup? I can use drag and drop nice and easy when setting up my simulations for the first time, but after having run them, if I want to add extra expressions, they will always be added to the bottom of the list and the drag and drop ability is lost (it shows the "forbidden" symbol"). In the best case, I'm able to drag the new expression, but it ends up swapping with another one of the same test instead of being added to the same cluster of expressions.
See illustration to know what I mean specifically:
Thank you in advance and best regards,
L.
    1. No, this is not possible
    2. As a workaround, click on the Test column header in the output pane to sort by test name, and then click on the right-most icon in the toolbar (the curved clockwise arrow) which has the tooltip "Reset table to display per-test evaluation order". You have to change the sort order to be something else first before that icon gets enabled, but when you've done that, all the new expressions will then be together with the others from the same test.
