  3. How can I access/change stdVia enclosures in SKILL?
  • Replies 11
  • Subscribers 150
  • Views 9838
pilotrp
pilotrp over 9 years ago
I'm using Virtuoso version ICADV12.3-64b.500.9.  Currelntly, our defualt setup creates metal enclosures that are coincident with the cut shape boundary.  I'd like to modify the enclosures using SKILL to make them DRC clean.  Here's one example:
via~>viaHeader~>??
(db:0x3898833b cellView db:0x3898961a objType "stdViaHeader"
prop nil viaDef db:0x181f01ba viaDefName
"C9CKK1" master db:0x2071ec9a subHeaders nil
vias
(db:0x38987e27) overrideParams nil
I looked at the overrideParams in another via where I had manually edited the enclosures.  I saw this:
via2~>viaHeader~>??
(db:0x3898831b cellView db:0x3898961a objType "stdViaHeader"
prop nil viaDef db:0x181f01a7 viaDefName
"M0V0M1" master db:0x3a74ff1a subHeaders nil
vias
(db:0x38987e1c) overrideParams
(("layer1Enc"
(0.025 0.0)
("layer2Enc"
(0.008 0.025)
I tried assigning the overrideParams to a similar list with different numerical values, but it errored out.  It also appears that the overrideParams property is nil unless you manually adjust the enclosures.
Can you tell me how I can adjust the via enclosures using SKILL for set of selected vias?
  • psill000
    psill000 over 9 years ago
    The via coloring names are different from the metal coloring
    Via noColor = noColor mask1 = noShift mask2 = shift1
    Metal grayColor mask1Color mask2Color
    Depending on your flow, it might be easier to have all your vias gray and let the metal to determine the color.
    procedure(allCellviewViasGray()
    let(    (
        (cv geGetEditCellView()))
    when(equal(cv~>mode "a") then
    foreach(viaDb cv~>vias
       grayViaColor(viaDb))
    hiRedraw()
    t
    ); end of let
    ); end of allCellviewViasGray
    procedure(grayViaColor(viaDb)
    ;noColor = noColor mask1 = noShift mask2 = shift1
    dbSetViaColorStateLocked(viaDb nil)
    dbSetViaLayer1Control(viaDb "noColor")
    dbSetViaLayer2Control(viaDb "noColor")
    ); end of grayViaColor
    Paul
