  3. How can I access/change stdVia enclosures in SKILL?
  • Replies 11
  • Subscribers 150
  • Views 9829
pilotrp
pilotrp over 9 years ago
I'm using Virtuoso version ICADV12.3-64b.500.9.  Currelntly, our defualt setup creates metal enclosures that are coincident with the cut shape boundary.  I'd like to modify the enclosures using SKILL to make them DRC clean.  Here's one example:
via~>viaHeader~>??
(db:0x3898833b cellView db:0x3898961a objType "stdViaHeader"
prop nil viaDef db:0x181f01ba viaDefName
"C9CKK1" master db:0x2071ec9a subHeaders nil
vias
(db:0x38987e27) overrideParams nil
I looked at the overrideParams in another via where I had manually edited the enclosures.  I saw this:
via2~>viaHeader~>??
(db:0x3898831b cellView db:0x3898961a objType "stdViaHeader"
prop nil viaDef db:0x181f01a7 viaDefName
"M0V0M1" master db:0x3a74ff1a subHeaders nil
vias
(db:0x38987e1c) overrideParams
(("layer1Enc"
(0.025 0.0)
("layer2Enc"
(0.008 0.025)
I tried assigning the overrideParams to a similar list with different numerical values, but it errored out.  It also appears that the overrideParams property is nil unless you manually adjust the enclosures.
Can you tell me how I can adjust the via enclosures using SKILL for set of selected vias?
  • psill000
    psill000 over 9 years ago
    This worked for stdVia for me
    viaDb~>layer1Enc = list(max(ovlp1 ovlp2) min(ovlp1 ovlp2)))
    viaDb~>layer2Enc = list(min(ovlp1 ovlp2) max(ovlp1 ovlp2))
  • skillUser
    skillUser over 9 years ago
    Hi Rob,
    I don't think that you can change the via header override parameters, but as Paul noted, you should be able to change the overrideParams for via objects. If the desired viaHeader already exists, you can just change the via object to point to the desired viaHeader.
    Best regards,
    Lawrence.
  • pilotrp
    That worked. Thanks so much!
  • pilotrp
    This worked for me, but I couldn't find any documentation regarding access and/or making changes to other stdVia parameters like this.  Can you point me to some documentation?  For example I took a guess and found viaDb~>cutColumns and viaDb~>cutRows.  Maybe there is access to others, but you need to know the exact parameter names.
    Rather than hunt it down in the documentation (if it's there, it's well hidden - the via stuff is not terribly well documented), what I tend to do is use the edit properties to change the via, and then use:
    car(geGetSelSet())~>viaHeader~>overrideParams
    to see what the parameters are called and what they've been set to. Then you know the parameter names for operations such as the above.
    Hope that helps (as a pragmatic trick)!
  • psill000
    Diito what Andrew said.
    I dont have a list of all the variable for vias symbolics
    Some of the variables for stdVia and customVia are slightly different
    Example
    stdVia
    cutRows
    cutColums
    customVia
    cutRow
    cutColum
    Same variables
    cutWidth cutHeight cutSpacing
    If you can get your Cadence AE is give you an old SKILL small book.
    The book has all the functions in the finder gui. The book is kinda handy for something to thumb through
    Paul
  • pilotrp
    Thanks for the help guys. I'll use those tips.
    You can see the allowed names from a post I made a few years ago which attempted to retrieve the current values from the viaDef or viaHeader override params and then increment them. This isn't strictly necessary (I think I was under mistaken assumption at the time) because you can just do viaInst~>cutWidth (for example) which will retrieve either the override value or the default depending on what's set.
    However, at the very least it serves a useful purpose of telling you all the parameter names for a stdVia:
    https://community.cadence.com/cadence_technology_forums/f/48/p/20735/1305030#1305030
    The parameter names for a customVia may vary, because the point is that it's a pcell (or even a fixed layout) and so you then have some flexibility over whatever the parameters were called when the pcell was implemented.
  • pilotrp
    Can someone tell me how to access/change these parameters on a standard via in SKILL and what the acceptable values are?
  • skillUser
    Hi Rob,
    There are a few functions that I think will help:
    dbGetViaCutLayerControl()
    dbGetViaLayer1Control()
    dbGetViaLayer2Control()
    dbSetViaCutLayerControl()
    dbSetViaLayer1Control()
    dbSetViaLayer2Control()
    dbSetViaColorStateLocked()
    dbSetViaColorStateLayerLocked()
    There are a couple of other functions but I think the above should give you what you need.
    Best regards,
    Lawrence.
