  3. How to generate cells (layout view) from a txt file or csv...
  • Subscribers 150
  • Views 17757
How to generate cells (layout view) from a txt file or csv file using pcell and skill code?
jyzxyz
jyzxyz over 9 years ago
I have a pcell for device level (nmos, pmos, etc.) layout creation. I know I can input the parameters using the GUI window. But to generate many cells, it would be convenient to create a txt or csv file with different parameters. Could the experts here teach me how to read such a file and then generate as many cells (layout view) as needed using skill code?
Thank you very much!
  • drdanmc
    drdanmc over 9 years ago
    for reading a text or csv file you can do something like:
    fp = infile("name_of_csv_file")
    while( gets(line, fp)
    ;; get rid of terminating new line (if needed)
    line = substring( line, 1, strlen(line)-1)
    ;; break into a list with an element for each entry
    data = parseString(line, ",")
    ;; now do stuff with data
    For adding instances to a layout the basic way is:
    ;; open the layout you want to write to
    ;; "a" == append to cell
    ;; "w" == overwrite cell
    cv = dbOpenCellViewByType("mylib" "mycell" "layout" nil "a")
    ;; open (for reading) the cell you want to instantiate
    master_id = dbOpenCellViewByType("pdklib" "nmos" "layout" nil "r")
    refdes="I3" ;; some refdes (if you want to control it)
    xy=12.3:45.6 ;; x-y location
    orient = "R0" ;; other choices are "R90", "MY", etc.
    new_inst = dbCreateInstance(cv, master_id, refdes, xy, orient, 1, t)
    now you can update parameters on the newly created instance whose ID is in new_inst, for example:
    new_inst->w = 6.8
    new_inst->l = 0.8
    Read the manual part about the functions here and that should at least get you in the right area of the docs to get going.
    You may want to read this:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000naD6EAI&pageName=ArticleContent&sq=005d0000001T3WNAA0_201729191014469
    and then read the solution that triggers callbacks that is mentioned in that article.
  • jyzxyz
    Dan,
    Thank you very much! It works very well.
