  3. hot keys for these commands...
  • Views 16568
sl101
sl101 over 9 years ago
I really need to create some hotkeys for these commands but I cannot find the skill script for it , please help :
1) Delete all probes
2) Find signal..
thanks
    The first is geDeleteAllProbe() . Not sure which command you are referring to for the second? Is this on a menu? If so, where and in which application?
    It will probably be blindingly obvious once you've said, but it's late in the evening and nothing came to mind.
  • dmay
    dmay over 9 years ago
    My recommendation is to go to the CIW->Options->Log Filter form. Turn on the Accelerated input option and press OK. Then run the command from the menus and look in the CIW to see what command was called. You can then create a hotkey for it. Be aware that many things will be recorded in the CIW, including cancelling the form and making the form active. These are not needed for the bindkey.
    Derek
  • sl101
    Got it. Thank you!!!
