  3. leYankFigs
  • Views 15952
leYankFigs
Toshiro
Toshiro over 9 years ago
Can you help me to configure bindKey leYankFigs:
I would like create a bindKeys Yank and I would like fixe myself the reference point with the mousse for the paste
Thanks for your help
    In the default bindkeys, the "y" key does a yank (calls leHiYank()) , and shift-Y does a paste (calls leHiPaste()). It's not clear to me what you want to do differently...
  • Toshiro
    Thanks for your help.
    But with the function leHiYank it's not possible to set by the user the reference point who I use during the paste (leHipaste).
    I want configure the function leYankFigs with the same option than the function leHiYank but I would like add the reference point for my paste leHipaste
    Florian
    Hi Florian,
    You could use this code, and then add a bindkey for CCFyankFigs().
    procedure(CCFyankFigs()
        enterBox(
            ?prompts list(
                "Point at the first corner of the yank rectangle"
                "Point at the opposite corner of the yank rectangle"
            ?cmdName "CCFyankFigs"
            ?doneProc "CCFyankFigsDone")
    procedure(CCFyankFigsDone(win ok points)
        let((cv rect refPoint)
            when(ok
                cv=geGetEditCellView(win)
                refPoint=enterPoint(
                    ?prompts list("Point at reference point for yank")
                destructuringBind(((llx lly) (urx ury)) points
                    rect=list(llx:lly urx:lly urx:ury llx:ury)
                    leYankFigs(cv rect 32 refPoint)
    Unfortunately I've found that the reference point is broken for leYankFigs from IC617/ICADV122 onwards. I filed CCR 1767467 to get this fixed (it worked in IC616 and before; how the reference point when  you paste is always the lower left corner). You might want to contact customer support and get a duplicate filed so you can track this?
  • Toshiro
    Thanks for this procedure.
    But I would like know is it's possible or can you tell me how I can make this following procedure:
    Step 1:
    I select shape, and/or instance, and/or pins ... (This action is doing by myself => user)
    Step 2:
    I want use the function leHiYank or leYankFigs or a other function
    Step 3:
    Define my reference point for my paste ( Step 4)
    Step4:
    Paste in the same windows, or a other windows, or in the hierarchy top or bottom or into the group
    The reference point for the paste is define in the Step 3
    Florian
    Florian,
    Since yank was extended to support pre-selection of objects, the non-procedural API was not extended (or added) to allow you to do this. So it can't be done with the APIs currently - I did file CCR 1768038 asking for an API to allow yanking a list of objects with a reference point.
    One other possibility (if using IC617 ISR8 or later) is to use:
    envSetVal("layout" "enableCopyAndPaste" 'boolean t)
    and then when you do a conventional copy - select the objects, hit "c" to copy, set the reference point and then hit escape (rather than actually copying) you can then do paste and it will honour the reference point.
