  3. Top level ADC testbench
  • Views 15595
tobiasedstrom
tobiasedstrom over 9 years ago
I am running simulations on an ADC. I use ADE-L to generate the netlist and the testbench itself is written in skill .
I have until now used Spectre as simulator and it have worked flawless. I found some AMS configurations however, that could be used to improve simulation speed (which is a major concern). So i decided to change simulator from Spectre to AMS.
The process is that I generate a VAMS netlist from ADE, then the skill testbench picks it up, setting all necessary variables and starts the simulation. When changing simulator, the simulation does not even start so i assume there are some errors in the configuration.
The following errors is shown in the log.
*Error* putprop: first arg must be either symbol, list, defstruct or user type – nil
and some of the following errors, for different variables
I dont really know were to start debugging, so i would appreciate any hints or ideas :)
Tobias
    That's a rather non-specific error - generally suggests that some low level code is dealing with data it wasn't expecting, and didn't catch it properly. I also don't know what you mean by a SKILL test bench in this case.
    I suggest you contact customer support - it's really going to be hard giving advice without seeing the details, without them just being wild stabs in the dark!
