  3. Advanced Boolean Engine: Is it safe for Pcells?
  • Views 16147
tweeksii
tweeksii over 9 years ago
ABE functions cannot be used in SKILL code for creating Pcells.
--Virtuoso Layout Suite SKILL Reference, Chapter 18
When you create SKILL routines within Pcells, use only the following functions:
The SKILL functions documented in the Cadence SKILL Language Reference; for example, car, if, foreach, sprintf, while.
SKILL functions from the following families:
db      dd      cdf
rod     tech    abe
cst     tx
--Virtuoso Parameterized Cell SKILL Reference, Chapter 1
So is ABE safe for Pcells or not??
    Andrew Beckett over 9 years ago +1
    From IC617 ISR9 (due to CCR 1511269) these functions were made available for use in PCells (i.e. they're in the right libraries/executables now). It's just that not all the documentation has caught up…
    From IC617 ISR9 (due to CCR 1511269) these functions were made available for use in PCells (i.e. they're in the right libraries/executables now). It's just that not all the documentation has caught up yet.
    So yes, it's safe. I filed CCR 1770248 to fix the documentation.
  • tweeksii
    Thank you, Andrew! ^_^
