  3. prboundary display issues
  • Views 15891
pilotrp
pilotrp over 9 years ago
I have some skill code that sets the visibility of selected sets of layers.  Here's an example:
procedure(OnlyC4()
leSetEntryLayer(`("C4" "drawing"))
leSetAllLayerVisible(nil)
ShowC4(t)
The problem with this is that the "leSetAllLayerVisible(nil)" command is turning off the display of my prboundary objects.  When I look at the Objects palette, the prboundary objects are set to "visible", but they are not displayed.  There must be a display layer associated with prboundary objects that is being turned off.  Is there a way to prevent this behavior?
Rob
    Rob,
    This appears to be a palette synchronisation issue. It's intended that changing the display of the prBoundary/boundary LPP affects the prBoundary object as well. If you control the visibility of that LPP directly, both parts of the palette update:
    leSetLayerVisible(list("prBoundary" "boundary") nil) ; or t
    If using leSetAllLayerVisible, and then I call leGetObjectVisible("P&R") afterwards then you can see it has been changed - just the P&R Boundary object in the Objects palette hasn't been updated.
    So to solve this you could do:
    procedure(OnlyC4()
      let((currentPR)
        currentPR=leGetObjectVisible("P&R")
        leSetObjectVisible("P&R" currentPR)
        ShowC4(t)
    May not need to record the current value and then set again at the end if you always want it to be displayed - just adding leSetObjectVisible("P&R" t) to your code would do that.
    I filed CCR 1770240 to get this fixed.
  • pilotrp
    Worked like a charm. Thanks Andrew!
