  3. how to get net for particular terminal
  • Views 17422
shashikumar22
shashikumar22 over 9 years ago
HI,
I want to get the net connected to a specific Term using skill, especially if the terminal is a bus (say IN<12:0>) and net connected to it is not in proper bit format. See figure below.
when i run  :inst is db id of instance Test_1
inst~>instTerms~>net~>name  => ("IN_STDBY" "ABC_SET" "TRANSs<12:8>,<*2>VSS,VDD,<*2>VSS,T1,TRANS<1:0>" "ABC<36:27>" "En_2" "STOPBY" "STOPPWR")
inst~>instTerms~>term~>name  => ("STDBY" "SET" "IN<12:0>" "OUT<36:27>" "En" "En1" "En2")
However can somebody tell me if there is any code of function which can give  net for each bit directly ?  eg : IN<7> is connected to VSS etc
  • psill000
    psill000 over 9 years ago
    Have you tried
    dbFindNetByName(
    d_cellView
    t_name
    I think you want something like this:
    mapping=foreach(mapcan instTerm inst~>instTerms
      foreach(mapcar (termName netName) dbProduceMemName(instTerm~>term~>name) dbProduceMemName(instTerm~>net~>name)
        list(termName netName)))
    The inner foreach mapcar will expand both the terminal name and net name into individual members and give you a list of one to one mappings. The outer foreach mapcan will concatenate all those together as it iterates over each instTerm.
    Hope that helps!
  • shashikumar22
    This is exactly what i wanted, this code worked perfectly :-)
    Thank you so much!
