  3. SKILL code to get Cadence License Server Host Id .
  • Subscribers 148
  • Views 28073
Marben
Marben over 9 years ago
Hi All,
How to get Cadence License Server Host Id using SKILL ?
Because, I want to subscribe in cadence online support(https://support.cadence.com) .
I am using IC5141.
Best regards,
Marben
    Marben,
    As far as I know, there is no SKILL API (private or public) to retrieve this information. It may not be trivial because there may be multiple license servers in the path anyway.
    Generally speaking you'd have to look at $CDS_LIC_FILE (or $LM_LICENSE_FILE) and then look at the lmgrd processes running on those machines, locate the file, and that should tell you the hostid used for that machine in the SERVER line at the top. In some cases machines may have more than one hostid so simply running lmhostid on the machine may not be enough (although it usually would be enough).
  • Marben
    Thank you very much for your reply.
    Best regards,
    Marben
  • Marben
    Hi All,
    I found the Cadence License Server Host Id by using the command line "lmstat -a" .
    Also by reading this post, groups.google.com/forum
    Thank you very much .
    Best regards,
    Marben
