  3. Skill regex pcre {} quantifiers
  • Views 19091
FlxZer
FlxZer over 9 years ago
Hello folks,
 I'm trying to come up with a pcre pattern that would match at least 4 times (4 or more)  a given substring from parent string. Reading through Cadence documentation I found exactly what I need in sklangref.pdf on page 169. The example written there is this:
comPat3 = pcreCompile( "z{1,5}" ) => pcreobj@0x27d120
pcreExecute( comPat3 "zzzzz" ) => t
From my understanding, pcreExecute() should return => t  when "z"  is found at least 1 but not more than 5 times into given string. Is that correct ? I do have some perl background so I might be biased. So, If this assumption is correct the following piece of code should return nil
Theoretically:
pcreExecute( comPat3 "zzzzzzz" ) => nil
comPat3 = pcreCompile( "z{2,5}" ) => pcreobj@0x27d120
pcreExecute( comPat3 "z" ) => nil
However, when put to the test, the result is t
Practically:
pcreExecute( comPat3 "zzzzzzz" ) => t
pcreExecute( comPat3 "z" ) => t
Is there a piece of information I've missed on {} quantifiers or this is some sort of a bug?
And finally, this is how I end up asking this question. I am facing the following problem. I have a string with variables, which all have same prefix. I want to be sure that this string has at least 4 variables in it with "Don" prefix. Example:
str1 =  "  Don1 Don1_x Don1_y Don1_l Don1_w"
comPat1 = pcreCompile( "Don{4,}" )
pcreExecute(comPat1 str1) => (theoretically should return t, but it returns - nil)
str1 =  "  Don1 Don1_x Don1_y Don1_l"
str1 =  "  Don1 Don1_x Don1_y"
pcreExecute(comPat1 str1) => (theoretically should return nil. Practically it really does - nil)
    The first example (with z's) are because the pattern is not anchored. What I see is if I do:
    comPat3=pcreCompile("z{2,5}")
    pcreExecute(comPat3 "z") ; nil
    pcreExecute(comPat3 "zz") ; t
    pcreExecute(comPat3 "zzzzz") ; t
    pcreExecute(comPat3 "zzzzzz") ; t
    The pattern is not anchored, so this means it is patching a sequence of 2 to 5 z's anywhere in the string. The last has 5 z's (which match) followed by some other characters, which happen to be a z. You could solve this by doing:
    comPat3=pcreCompile("^z{2,5}$")
    which means that the match can ONLY be zz, zzz, zzzz, or zzzzz. Anything else will return nil. Or you might need to make it more complex if you want to allow other characters:
    comPat3=pcreCompile("(^|[^z])z{2,5}([^z]|$)")
    This matches either the beginning, or a character other than z, followed by 2 to 5 z's, followed by any character other than z or the end of the string.
    For your second pattern, the repetition is on the "n" only. So you are asking for something with is Donnnn at least. That's not what you want.
    comPat1=pcreCompile("(Don\\S*\\s*){4,}")
    is probably what you want (I've not bothered with anchoring). What this is trying to match is Don followed by any number of non-space characters followed by any number of spaces, and then 4 or more repetitions of all of that (it's in parentheses to group the pattern).
    Note this is really not related to the implementation in SKILL (other than the \s and \S needing double escapes because of backslash having special meaning in SKILL strings). You could see the same syntax if you did "man perlre" - the syntax is using the Perl Compatible Regular Expression library.
  • FlxZer
    Thanks Andrew, your solution works. I had misinterpreted the example in the documentation. I do think, there should be more extensive information and examples on regular expression topic into Cadence doc.
    Point taken. However, the documentation does have a link to the PCRE web page, which is probably a better place to have a detailed coverage of the regular expression syntax rather than repeating it all directly within the Cadence help.
