  3. errset.errset always returns nil?
  • Views 16143
MatthewLove
MatthewLove over 9 years ago
I'm trying to use the errset function but I can't seem to get it to return the error message.
The docs give the following example:
errset( 1+"text" ) => nil
errset.errset =>
("plus" 0 t nil
      ("*Error* plus: can't handle (1 + \"text\")"))
But this is what I get when I type it into the CIW.
(errset (1 + "text"))
nil
errset.errset
nil
I'm on IC 6.1.6. Any ideas?
    This is because there is other SKILL code that is set up to run after each interaction in the CIW. That interferes with seeing errset.errset (it's been reset by other code that is triggered to run). In a program it would be OK, and also you can do:
    errset(1+"text") println(errset.errset)
  • MatthewLove
    Thanks a bunch Andrew, you're a life saver.
