  3. Problem in coping symbols through skill code in other new...
  • Views 16333
Problem in coping symbols through skill code in other new schematic window
conrel
conrel over 9 years ago
Hello Cadence,
I was trying to make the multiple copy of symbol in a new schematic design through skill code. But when trying to do that, it is copying only dummy symbol (only the outline of the symbol without any function of circuitry) . Please let me know if there is any mistake in code? . I am sharing the code here. please help me.
If there is any other reference material available to make automatic schematic through code(or the commands use to make schematic through skill), please provide that too.
First i am opening the new cellview in cadence and then running the command to run this file.
procedure(ishu(Design_Lib_Name cell_Name row col)
new_design = geGetEditCellView()
cellCV_Name = dbOpenCellViewByType(Design_Lib_Name cell_Name "symbol")
orientation="R0"
for(i 0 row-1
for(j 0 col-1
cellInst = dbCreateInst(new_design cellCV_Name "cellInst" list(8*i, 8*j) orientation)
dbFlattenInst(cellInst 1 t)
for(j 0 col-1
wireId=schCreateWire(new_design "draw" "full" list(-0.5+8*j:-2 -0.5+8*j:2+7*row) 0.05 0.05 0.0)
    Why are you flattening the symbol instances? Calling dbFlattenInst seems an odd thing to do here, so I'm assuming you didn't mean to do that?
  • conrel
    Thanks Andrew for your reply,
    But the problem sill exist. When i am removing this "dbFlattenInst(prchrgInst 1 t)" instruction.
    It is just copying that symbol only once with proper circuitry but not forming an 2D array as expected and giving a warning that "
    *WARNING* (DB-270000): dbCreateInst: Instance with name 'cellInst' already exists".
    What should be done to deal with this issue?
    Rajesh
    I'd have thought that the warning was pretty clear - you're calling dbCreateInst multiple times with the same instance name ("cellInst").
    Instead, change the second argument of dbCreateInst to either be "" (which means they will be auto-named) or pass an expression which creates a unique instance name, such as sprintf(nil "cellInst_%d_%d" i j) .
  • conrel
    Thanks Andrew,
    I did that but the problem is still the same. Posting my modified program again with the screen-shot of output too. Please see to it.
    procedure(ishu(design_Lib_Name cell_Name row col)
    cellCV_Name = dbOpenCellViewByType(design_Lib_Name cell_Name "symbol")
    orientation="R0"
    count=0
    for(i 0 row-1
    for(j 0 col-1
    sprintf(cellInst "cellinst_%d_%d" i j)
    cellInst= dbCreateInst(new_design cellCV_Name "cellInst" list(3*i, 3*j) orientation)
    for(j 0 col-1
    wireId=schCreateWire(new_design "draw" "full" list(-0.5+3*j:-2 -0.5+3*j:2+2*row) 0.05 0.05 0.0)
    Hardly surprising because the third (I think I said second before by mistake as I was replying on my phone) argument is still the literal string "cellInst" and so a fixed name. There is a difference between a literal string and the name of a variable. Your code should have:
    cellInstId= dbCreateInst(new_design cellCV_Name cellInst list(3*i, 3*j) orientation)
    Note that I changed the name of the variable of the return value of dbCreateInst to avoid confusing it with the variable containing the name (in your case it doesn't matter because the return value of dbCreateInst is not being used, but it's best to avoid repurposing the same variable for different things because it's easy to get yourself in a mess if you do.
