  3. probeDisplayStyle default value can be changed?
  • Views 15106
Starview
Starview over 9 years ago
Hi all,
I'm using IC614 and trying to make a net probe in schematic by geAddNetProbe() command. I know it has a property called "probeDisplayStyle" and its default value is "object".
Then is it simply possible to change the default to "flight" with submitting geAddNetProbe?  If not, is there any other way to realize adding net probe with probeDisplayStyle="flight" ?
I like to submit this from bindkey.
BR,
Starview
    I don't think there's a way of doing this, other than writing your own wrapper function which just does:
    procedure(CCFaddNetProbe(@rest args)
      let((probe)
        probe=apply('geAddNetProbe args)
        probe->probeDisplayStyle="flight"
        probe
    Then call CCFaddNetProbe instead of geAddNetProbe.
    Andrew,
