  3. Questions about using EIP mode
  • Subscribers 150
  • Views 15224
MalcolmWhite
MalcolmWhite over 9 years ago
I was wondering if there is some sort of function or enviroment variable which tells my skill code that I am currently in EIP mode versus working currently in hierarchy level 0.
So far I was able to just check hiGetCurrentWindow()~>topcell==hiGetCurrentWindow()~>curCell .
Also , wondering , since I can't obviously use hiGetPoint()  when in EIP mode since that returns top level coordinates, I have to use (I think without looking) its hiGetEditToWindowPoint()
but I also noticed that hiGetWindowToEditPoint() does the reverse which (I think again without looking) you would pass to a child subcell coordinates from top level , but I cannot figure out
why someone would pass top level coordinates to a subcell.  What use would that be ??
Thanks for your consideration.
  • psill000
    psill000 over 9 years ago
    I use deGetEIP to test if the cellview in edit in place mode.
    As for the other part of your question, I depends in the script writer need.
    Paul
  • MalcolmWhite
    thanks for your help!
