  3. SKILL: Need to detect Duplicate Coincident Instances in...
  • Subscribers 150
  • Views 15369
SKILL: Need to detect Duplicate Coincident Instances in Hierarchy
EdwardDodge
EdwardDodge over 9 years ago
Hi Guys,
I've been using leSearchHierarchy to find duplicate coincident instances (instances overlaid on top of each other). Of course this command only gives a list of candidates. And for level-0 instances the job is easy: just compare if inst1~>transform & inst2~>transform are the same.
However, transform information is *relative* to the instance's level of hierarchy. How would I transform the transform info from instances lower down the hierarchy to make them directly comparable to the same transform from instances at level-0?
Thanks ahead of time,
Edward
  • psill000
    psill000 over 9 years ago
    I think I understand what you want. I dont know of a function or an easy why of comparing overlaps or overlays.
    Maybe to keep the data from grow too big, you might want to divide the top level in segments.
    You dont need to compare opposite side instances.
    I would use dbConcatTransform get the transform from top level.
    Sorry I could give an easier answer.
    Paul
