  3. How to fetch the "pass/near/fail" state from other expressions...
  • Views 2371
How to fetch the "pass/near/fail" state from other expressions?
fatcat1206
fatcat1206 over 9 years ago
Hi All
I'd like to know where there is a function to fetch the "pass/near/fail" status for other expressions in the same run.
Currently, I have a setup like
expr1    spec1
expr2   spec2
expr3   spec3
And then I want to have the fourth expression to give me the summary, it has "pass" status when expr1~3 are all passed.
simply like the "pass/fail" results in a corner sweep for a signal expression.
Best Regards
Yi
    Hi Yi,
    Currently there isn't a way to do this. I was looking at CCR 907219 which is sort-of related to do this - that's probably a prerequisite though. This is asking for the pass/fail status to be stored in the RDB (at least accessible from the result database).  There is the maeGetSpecStatus function in Assembler/Explorer but this doesn't work properly when used in point expressions (I tried) - even if you use internal private functions to access the current point Id.
    So I created CCR 1780084 to get this enhancement made.
  • fatcat1206
    Hi Andrew
    Thank you very much for the help.
    I feel this feature will be really helpful when building up outputs to cover requirement.
    Most of the time, the requirements are quite general, such as:
    check all the outputs from a current mirror, they should be with in a range of integer multiply of [a, b]
    And then in the implementation, every output need to be checked with two expression, one for minimum and another for maximum.
    With this feature, I can write a expression to have the summary of each individual checkers, and mapped this one to the requirement.
    Although currently I can write something like "if(a<expr1 && expr1<b && 2*a<expr2 && expr2<2*b,0,1)" to generate the summary.
    P.S "0" represents "pass", "1" represents "fail"
    The main drawback is that the spec is hard coded in the expression. When the spec changes, the summary expression cannot be updated automatically.
    This introduce quite some work to maintaining the test bench, and can easily introduce human error.
    I am looking forward to see this enhancement. And believe the ADE Verifier can benefit from it.
    Best Regards
    Yi
