  3. Invoke Callbacks in Pcell and PVS
  • Views 17924
TobiasMrks
TobiasMrks over 9 years ago
I am building a PCell which includes a transistor of a PDK and to invoke the callbacks I am using the CCSinvokedCallbacks function recommended in "How to call CDF callbacks procedurally from SKILL?".
I am loading the CCSinvokedCallbacks file:
load("CCSinvokeCdfCallbacks.il")
    I call the CCSinvokedCallbacks in my PCell code and when I include my PCell in the layout, it works!
    But when I am now using PVS to check for drc errors I get the following errors:
    *WARNING* (DB-270001): Pcell evaluation for TESTS/test/layout has the following error(s):
    *WARNING* (DB-270002): ("eval" 0 t nil ("*Error* eval: undefined function" CCSinvokeCdfCallbacks))
    *WARNING* (DB-270003): Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
    ERROR (XSTRM-231): Pcell evaluation failed for 'TESTS/test/layout' because the pcell SKILL code contains either a syntax error or an unsupported XStream function. Check the standard output or the Virtuoso log file for more information. Either correct the pcell SKILL code or ignore the error by enabling the 'ignorePcellEvalFail' option for XStream Out.
    INFO (XSTRM-273): Translation failed. '1' error(s) and '6' warning(s) found.
    What is the recommanded way to get around this?
    Thank you in advance.
    Best regards
    Tobias
      Tobias,
      Happy to see you using my code to good effect!
      Anyway, what you should do is to add a file called "libInit.il" inside the library containing the pcell. This file should then load the CCSinvokeCdfCallbacks.il file.
      The idea is that the first time the library is accessed in Virtuoso, in the stream interface or any other application that reads the database, it will load the libInit.il which will in turn load the callback-calling code. This means you wouldn't need to load the code from your .cdsinit as it would be auto-loaded from the libInit.il file.
      Hope that helps,
    • TobiasMrks
      I added he libInit.il and loaded the CCSinvokeCdfcallbacks.il there.
      But now I call:
      CCSinvokeCdfCallbacks(cv ?callInitProc t ?useInstCDF t)
      I get the following errors from xtream:
      *WARNING* (DB-270001): Pcell evaluation for cmos22/nfet/layout has the following error(s):
      *WARNING* (DB-270002): ("quotient" 0 t nil ("*Error* quotient: can't handle (\"iPar(\\\"w\\\")/iPar(\\\"nf\\\")\" / 1e-06)"))
      ERROR (XSTRM-231): Pcell evaluation failed for 'cmos22/nfet/layout' because the pcell SKILL code contains either a syntax error or an unsupported XStream function. Check the standard output or the Virtuoso log file for more information. Either correct the pcell SKILL code or ignore the error by enabling the 'ignorePcellEvalFail' option for XStream Out.
      INFO (XSTRM-273): Translation failed. '1' error(s) and '5' warning(s) found.
      When I comment out this line I do not get any errors but also no callbacks of course.
      Do you have an idea where the problem could be coming from
      Best regards
      Tobias
    • TobiasMrks
      Ok I solved the problem when I give the CCSinvokeCdfCallbacks() function an order for the parameters to trigger the callbacks it will work for some reason in Xstream too.
