  3. Creat blockage from polygon?
  • Replies 7
  • Subscribers 150
  • Views 18158
blankman
blankman over 9 years ago
In virtuoso i'm wondering if its possible to create a routing blockage from a set of polygons? I have tried the auto feature however it only creates the boundary box of the selected set, not individual polygons.
Thanks in advance,
Brian.
    I threw together a few lines of SKILL to do this:
    /* CCFcreateBlockageFromSelection.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jul 24, 2017
    Modified
    By
    SCCS Info: @(#) CCFcreateBlockageFromSelection.il 07/24/17.17:04:59 1.1
    *         CCFcreateBlockageFromSelection(["routing"])          *
    *      Create routing blockages from the selected objects      *
    procedure(CCFcreateBlockageFromSelection(@optional (type "routing"))
      let((points temp)
        foreach(obj geGetSelSet()
          when(obj~>isShape
            ; Generate points for different source types. For paths
            ; and pathSegs, easiest to copy, convert to polygon and
            ; then use the point list.
            points=
              case(obj~>objType
                ("polygon" obj~>points)
                ("rect"
                  destructuringBind(((llx lly) (urx ury)) obj~>bBox
                    list(llx:lly urx:lly urx:ury llx:ury)
                ("path"
                  temp=dbCopyFig(obj obj~>cellView)
                  temp=dbConvertPathToPolygon(temp)
                  prog1(
                    temp~>points
                    dbDeleteObject(temp)
                ("pathSeg"
                  temp=dbConvertPathSegToPolygon(temp)
                  prog1(
                    temp~>points
            dbCreateLayerBlockage(
              obj~>cellView
              obj~>layerName
              type
              points
        t
  • blankman
    Andrew, great, appreciated, thanks, Brian.
  • RK56
    RK56 over 9 years ago
    Why did you group the two lines inside prog?
    -Ramakrishnan
    Ramakrishnan,
    I'm using prog1 (not prog) because I want the return value of each branch in the case function to be the list of points (you'll see the return value is stored in the variable points). Because I need to retrieve the list of points from the temporary object and then delete it, I use prog1 - prog1 executes all the statements in order but the return value is the first statement executed (as opposed to the usual convention of the last thing executed). So here the prog1 returns the list of points and then deletes the object from which it had retrieved the list of points. It avoids needing to use another variable - of course, I could have moved all the points= assignments inside the case statement but I'd already written the part which handled rect and polygon and then thought I probably should add path and pathSeg for completeness.
  • RK56
    Thanks Andrew. I learnt something here today.
    -Ramakrishnan
  • Vishhh
    Vishhh over 8 years ago
    Thanks Andrew,. for the answer..
    Could you please let me know how to use the same proc for creating blockage of type 'placement'  ?
    I need to do it in my script..
    - Vish
    Vish,
    In the code above, replace:
              obj~>cellView
              obj~>layerName
              type
              points
    with:
            dbCreateAreaBlockage(
              obj~>cellView
              points
    Note, I did not test this - it's just from reading the manual!
