  3. Limitation of evalstring and ML text field
  • Subscribers 148
  • Views 16002
RK56
RK56 over 9 years ago
I have written a GUI where I let the users to write/paste skill script in a ML text field. I see people pasting very large text files inside the field. This concerns me. I want to know when does this method break? Which one overflows first? The ML field or evalstring/errset?
-Ramakrishnan
    Ramakrishnan,
    I just created (using SKILL) some code which was 5Mbytes long and both the ML text field and evalstring had no problem with this. So in practice I doubt you'll hit any limitations... the only limitation you'd likely to hit is if you end up with exceeding the maximum function size (hard to describe because it depends on many things) or the value stack overflowing. This would only happen with extremely large SKILL function definitions - and only ever tend to be reached in machine-generated code.
  • RK56
    Thanks for the testcase Andrew.
    I was lazy to do one. I'm wondering what isyour 5MB text code? Is it a print statement with a counter?
    Here's what I threw together (I wrote it in C syntax rather than my preferred Lisp syntax just in case I had to share it!)
    strs=nil
    for(j 1 100
      nums=nil
      for(i 1 10000
        nums=cons(sprintf(nil "%d" i+1000) nums)
      str=strcat("println(" buildString(nums "+") ")")
      strs=cons(str strs)
    bigStr=buildString(strs "\n")
    procedure(myEvaluateIt(form)
      let((pat)
        pat=pcreCompile("\n")
        ; this replaces all the carriage returns with space so that
        ; it gets slurped in one go
        evalstring(pcreReplace(pat form->big->value " " 0))
        ; alternatively could use loadstring.
        ;loadstring(form->big->value)
    big=hiCreateMLTextField(?name 'big ?prompt "Big" ?value bigStr)
    hiCreateAppForm(?name 'myForm ?fields list(big) ?callback 'myEvaluateIt)
    hiDisplayForm(myForm)
