  3. Layout to schematic connectivity
  • Views 16578
psill000
psill000 over 9 years ago
What is command to define layout to schematic connectivity reference?
Paul
    lxSetConnRef(
    t_layLib
    t_layCell
    t_layView
    t_sourceType { CELLVIEW | NONE }
    [ ?schLib t_schLib ]
    [ ?schCell t_schCell ]
    [ ?schView t_schView ]
    => t / nil
    Sets or unsets the connectivity reference for a specified layout cellview without opening the layout view graphically. You must specify the layout view and whether the source type is NONE or CELLVIEW. If the source type is CELLVIEW, you can specify the schematic cellview to use (by default it is set to the schematic view in the same library and cell). The function also saves the layout cellview, but only if had not been modified prior to lxSetConnRef being called.
