  3. SKILL Q: Auto Create Row Objects
  • Subscribers 150
  • Views 16068
EdwardDodge
EdwardDodge over 9 years ago
Hi Guys,
Right now to create rows I choose VXL->Create->P & R Objects->Row...
From there I fill out the options:
1) Site Definition Name
2) Row Orientation
3) Options -> "Flip Every Other Row"
4) Create Method -> "Area Fill", "Partition", "prBoundary"
The SKILL documentation does not seem to provide a command that takes these options as arguments. Nor is there a SKILL command to auto-create row objects using these options to fill the prBoundary. Apparently this is not a one-step solution, but requires more knowledge of the row-creation API, perhaps an entire routine. Does anybody know if I missed a single-command solution or if there's a short routine that would do what I'm asking about?
Thanks in advance for your consideration.
Edward
  • Quek
    Quek over 9 years ago
    Hi Edward
    You can use dbCreateRow to create OA rows. Detail description of the cmd can be found in $CDSHOME/doc/skdfref/skdfref.pdf. The unified placer can also be used to automatically create rows with the prBoundary.
    Best regards
    Quek
  • EdwardDodge
    Thanks, Quek!
    I was hoping there was a one-stop-shopping solution that would auto-generate rows in any shape prBoundary like the row command I mentioned. But I took your advice and wrote a wrapper script around dbCreateRow to fill rectangular boundaries. It works like a charm!
    Edward
  • Quek
    Hi Edward
    There is already a one-stop-shopping solution. You can do it as follows:
    a. Switch to layoutXL mode using "Launch->Layout XL"
    b. Go to "Place->Custom Digital->Placement Planning"
    c. The form allows you to generate rows in the specific region or prBoundary
    Best regards
    Quek
  • EdwardDodge
    Hi Quek,
    I was asking about a one-stop SKILL command solution. I already know about how to do it through the menus. This is part of an placement automation project I'm doing. Digging through menus sort of defeats the purpose. ;)
    Edward
