  3. Adding missing top level layers to LSW layers when Edit...
  • Views 15631
Adding missing top level layers to LSW layers when Edit In Place
psill000
psill000 over 9 years ago
When I am in EIP, only the cellview's layers are populating the LSW.
Is there a command/variable that I can I add the missing top level layers into the LSW?
Paul
  • dmay
    dmay over 9 years ago
    If you right mouse click near the top of your Layer Palette there is a pop up menu that has an "Options" form. On this form you can set the Scope of Used Layers in EIP. Set this to be Top To Bottom. You can save this in your .cdsenv with this setting:
    layout          pteUsedLayersEipScope           cyclic      "topToBottom"
    Derek
  • psill000
    Booya, Big thanks
