  3. custom blind key not working
  • Views 15186
iqbalsahid
iqbalsahid over 9 years ago
I wrote this script in skill. All keys are working except Shift+0. I cant understand why? need help..
hiSetBindKeys("Layout" list( list("Shift<Key>0" "Simcreatevia( geGetWindowCellView() hiGetPoint( getCurrentWindow() ) 0 )")
                             list("Shift<Key>1" "Simcreatevia( geGetWindowCellView() hiGetPoint( getCurrentWindow() ) 1 )")
                             list("Shift<Key>2" "Simcreatevia( geGetWindowCellView() hiGetPoint( getCurrentWindow() ) 2 )")))
procedure( Simcreatevia( cv xy num )
        let( ( x1 x2 y1 y2 pos)
                case( num
                        ( 0
                                x1 = car(xy) - 0.034
                                x2 = car(xy) + 0.034
                                y1 = cadr(xy) - 0.022
                                y2 = cadr(xy) + 0.022
                                pos = list( list(x1 y1) list(x2 y2) )
                                dbCreateRect( cv list( "v0" "drawing" ) pos )
                                leSetLayerVisible( `("v0" "drawing") t )
                                leSetLayerSelectable( `("v0" "drawing") t )
                                leSetEntryLayer( `("v0" "drawing") )
                        ( 1
                                x1 = car(xy) - 0.03
                                x2 = car(xy) + 0.03
                                dbCreateRect( cv list( "v1" "drawing" ) pos )
                                leSetLayerVisible( `("v1" "drawing") t )
                                leSetLayerSelectable( `("v1" "drawing") t )
                                leSetEntryLayer( `("v1" "drawing") )
                        ( 2
                                 x1 = car(xy) - 0.022
                                x2 = car(xy) + 0.022
                                y1 = cadr(xy) - 0.029
                                y2 = cadr(xy) + 0.029
                                dbCreateRect( cv list( "v2" "drawing" ) pos )
                                leSetLayerVisible( `("v2" "drawing") t )
                                leSetLayerSelectable( `("v2" "drawing") t )
                                leSetEntryLayer( `("v2" "drawing") )
    Using Shift<Key>Number bindkeys is not a reliable way to define bindkeys since IC61 - instead  you probably want something like "Shift<Key>)" - or whatever character is on the key. There have been a few posts in the forums on this in the past, plus articles on Cadence Online Support.
    The way to check is to use Options->Bindkey in the CIW, pick the Layout Application, and the on the right side hit the Green + icon. With your cursor in the box with the key sequence, press Shift-0 and you'll see what encoding it puts there - just use that in your code.
  • iqbalsahid
    thanks
