  3. schematic PCELL : connecting a port of and arrayed Instance...
  • Views 16659
schematic PCELL : connecting a port of and arrayed Instance to a single terminal
mihirDesai
mihirDesai over 9 years ago
I tried to find an answer but could not find an exact answer so asking it here.
I have a simple pcell code where there is an arrayed instance "i0<10:1>" where one of the ports "MINUS" is connected to terminal "vssx" directly. (all MINUS terminals essentially shorted to vssx)
In a normal schematic I can just draw a wire between the two and it automatically connects them.
But when I try to do it in pcell code with dbCreateConnByName it give me this warning
*WARNING* (DB-270000): dbCreateConnByName: Net width does not match instance/terminal width.
and I dont see that connection happening in the design.
Does anyone know how to connect them using SKILL ?
Mihir
    Mihir,
    You'll need to create a net (e.g. with dbCreateNet) called "<*10>vssx" and then connected to that. This happens behind the scenes in the schematic editor, but in a schematic pcell you have to do it yourself.
  • mihirDesai
    Thanks !!
    It worked.
    I realize now if I check and save such name is generated in the properties window for the net wire.
    Mihir
