  3. Can a cell-level CDF stay with its cell, regardless of library...
  • Replies 14
  • Views 23565
Can a cell-level CDF stay with its cell, regardless of library?
caver456
caver456 over 9 years ago
In order to add control to pcell parameters in the edit parameters GUI (i.e. make a cyclic field, change the parameter display text, etc) I understand you need to use CDF.  (Interesting that this support case uses the wording that CDF is "the best method"... that implies there's another way... is that true?) - CDF works nicely, but, it looks like a base-cell-level CDF still depends on the library it was created with, i.e. if you copy that cell to a different library that doesn't have the same CDF, then the pcell edit parameters form will use the default display (i.e. actual pcell parameter names as the field labels; no cyclic fields; etc).  One post mentions that you can copy the CDF of the cell along with the cell itself by using ccpCopy but that seems pretty cumbersome and I didn't get it to work as expected.
The CDF docs seemed to indicate you could attach a CDF to a cell only, but maybe I'm misunderstanding?  Based on all of the above, it looks like a cell-only CDF is only valid for that cell when it is in the library specified in the cdfCreateBaseCellCDF command?
In other words, is there a way to get a nice clean modular independent pcell along with the user-friendly edit parameters form fields, such that the cell can be copied to any library and still work and look the same?
    The cell-level CDF is not specific to the library it was created with; if you copy the cell to another library, the CDF would go with it and it should still work. The only exception would be if you had any CDF callbacks which explicitly coded the library name into the callback - but there really shouldn't be a need to do that.
    Even if you copy (via the library manager) just the cellView (e.g. just the layout view) the default behaviour would be to copy the cell CDF (i.e. the cell's data.dm) too; there are settings in the Edit->Copy Preferences form that change this behaviour and these can be controlled in the .cdsenv too (this is in the Library and Cell Property Files section). You do need to be aware that if there already is CDF for that cell in the destination library then it would show up as a conflict during the copy, but that's fair enough in my opinion:
    The article you mentioned is specifically talking about stretch handle parameters and how to have them so that they can't be edited on the edit properties form. The alternative to creating a CDF parameter and then having it not display is to just not have the CDF parameter at all (but have CDF parameters for everything else) - so that's why it is described as the "best method". It doesn't mean that there's another way of defining the appearance of the parameters.
    So I think it actually behaves the way you want. No need to use ccpCopy to do anything special - standard library manager copy should copy everything needed.
  • caver456
    Thanks, that looked like the ticket, I was not aware of that form. However, still no luck, so there must be something I'm not understanding:
    Basically, as the acid test to see if the copy worked after each attempt as below, I did CIW -> Tools -> CDF -> Edit, scope=cell, layer=base (also tried effective and since I don't have any user cdf it is unchanged vs base); selected the source library and cell to make sure it looks as expected (each parameter has a row with prompt and all the relevant columns filled out) and then selected the target library and cell, and in each case there are no populated rows. Also tried the actual pcell placement of the copy target to reconfirm, and in each case it did not have the cdf-style fields.
    Looking at the doc description of copy preferences form, it's not too helpful - when I opened up that form, 'do not add dependent property files to copy sets' was selected (otherwise it's the same as the image you sent), so, I figured that was the problem. So I changed it to 'Automatically add...' and unchecked 'Libraries' to avoid the library's data.dm conflict warning, since I don't want to copy that anyway. Deleted the existing cell in the target location (i.e. the previous attempt), then did the copy again, and, no luck as above. Thinking something was just stuck in the cache, I deleted the target cell, restarted Virtuoso, selected 'Automatically add...', did the copy, no luck. Also tried the above with 'include every file inside each cellview'; no luck.
    Not sure why this didn't work - I suggest you contact customer support so that we can look into it in more detail.
    You might want to check in your .cdsenv file (home dir, and centrally - depends on how you've set up the lookup) for:
    cdsLibManager.copy              addPropFiles            boolean t
    cdsLibManager.copyGlobals addCellPropFiles boolean t
    cdsLibManager.copyGlobals addLibPropFiles boolean t
    Since yours was off by default, it suggests somebody has overridden the defaults.
  • caver456
    Will do in just a bit. Thanks
  • caver456
    While working the copy CDF question with customer support, I have another question for the forum on this topic of trying to make a completely self-contained and portable pcell.
    In the pcell code I'd like to use function calls to take care of things like repeating contacts along a line, removing duplicates from a list, etc. If those functions are defined outside of the pcDefincePcell function, they must be defined at pcell evaluation time by whatever means (the docs are pretty clear about this), but, that means the pcell is no longer truly self-contained. (I see in the docs you can attach the code to a library, but, can you attach code to a cell in the same manner?) If I put those function definitions inside the pcDefinePcell code, I get pcell markers due to "function blahblah redefined" on every evaluation of the pcell... but otherwise it works as expected. Is there a way to have reusable code within the pcell definition that does not bark about being redefined on every evaluation? It seems like there are some significant syntax changes that would be needed to replace the procedures with macros; is that the only option?
  • skillUser
    skillUser over 9 years ago
    You can redefine a function 'silently' - check if the function is already defined (e.g. use "fboundp") and if it is use putd('functionName nil) where functionName is your function. After doing this the function can be defined again without any warning message saying that it is being redefined. It is a small overhead but should give you what you are asking for. You could set up a foreach loop for each of the functions that you want to redefine so that they are all 'reset' in one go. In my understanding you do not want to try to rewrite everything as macros, this would not be recommended for various reasons.
    Best regards,
    Lawrence.
    In fact rather than redefining silently each time, it would be better to do:
    unless(isCallable('myFunc)
      procedure(myFunc(...)
    that way it only defines them if they've not been defined before.
    That said, it's then a bit more of a headache to maintain the code as you're developing it - so you might want to add an override in there:
    unless(isCallable('myFunc) || boundp('myRedefineAll) && myRedefineAll
      procedure(...
    Then you can just set a variable myRedefineAll=t and each code load would redefine the functions.
    Personally I wouldn't bother with this; adding functions into the libInit.il for the library is pretty standard practice - especially if you want to share the functions across more than one pcell.
  • caver456
    Thanks, works like a charm! Nested functions are now self-contained within the compiled pcell. After figuring out the copy-CDF-along-with-cell topic on customer support, it looks like we have a good solution for a pcell that is completely self-contained and portable: doesn't depend on any other code files, and doesn't matter what library it is copied in to.
    pcDefinePCell(ddObjStuff
    (params)
    let(()
    foreach(funcSym list('removeDuplicates 'mergeAllShapes 'fillWithContacts)
    if(fboundp(funcSym) then putd(funcSym nil))
    procedure(removeDuplicates
    Not sure if you've really called your functions that, but I'd recommend giving them unique prefixes to avoid clashing with somebody else who happens to use fairly generic function names such as removeDuplicates or fillWithContacts.
    Regards.
  • caver456
    Granted, this loses the advantages of reusing code across the library. The specific application here is that our CAD department provides a strictly supported set of pcells, and we want to make a few extra pcells of our own, on a quicker time table than what it would take to get CAD to support it. Since these pcells are basically home-brew but are subject to all the same DRC and LVS rules, we want to keep them completely separated, self-contained, and portable, i.e. without having to make any tech file or lib-level cd changes, any without having to make sure our custom code is always loaded by anyone who looks at these pcells. Seems like others may be doing similar tricks to accomplish similar goals? Or maybe there's a different tack on accomplishing a similar goal?
