  3. Scanning through symbol db
  • Views 15739
HDar
HDar over 9 years ago
HI, I am new to skill. I am trying to write a program that checks if there exist an ellipse shape (a bubble) near a negated pin (pins that are negated, it will have "N" at the end). To do this I am trying to get coordinates of both the pin and the bubble, check if the bubble is on the left side of the pin or not (for output pin, the bubble should exist on the right hand side of the pin text).
How do I scan through the symbol view db.
symView = dbOpenCellViewByType( "scratch" "DFF" "symbol" "" "r" ) ; <-- opening the symbol view to a variable
I am able to get the coordinates of all the bubbles that exist in the symbol, Also coordinates of all the negated pins, but in a separate loop. I want to try doing it in efficient manner ( using one loop ). Thank you for your help.
PS: If there is any document listing out sample scripts, if would be great help to me :)
-HD
    I'm not sure this is going to solve your problem. You could find all the shapes matching that pattern by doing:
    endInN(pcreCompile("N$"))
    shapesOnNegatedNet=setof(shape symView~>shapes pcreExecute(endInN shape~>net~>name))
    Oh, you've edited your post since  you first sent it. Anyway, this is unlikely to help because the bubble is not going to be on the net - it's just graphics in the symbol. Presumably you'd have to use the proximity of the shape to the pin figure for the negated terminals? Hard to know without seeing the style of symbols you've got (and even then, I don't think I have the bandwidth to write this for you).
    BTW, there are huge numbers of SKILL samples on these forums and also on Cadence Online Support.
  • HDar
    HI Andrew,
    Thanks for you reply.
    Yes, I edited my first post to be more clear as to what I am looking for.
    Here is a screenshot of my symbol (the area that I am interested in). Here SN port has a bubble, which is a negated port and that's expected.
    If the bubble is on R port then its wrong and I should be able to detect it. Thank you for your time. I will try to look for some sample scripts in cadence community and try to find a way around.
    Himanshu
    Himanshu,
    I threw together this example to show one way that you could potentially do this check. It may not be exactly what you want, but it shows one way of approaching it.
    /* CCFcheckBubbles.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Aug 07, 2017
    Modified
    By
    Example function for checking a symbol to see if it has
    bubbles on non-negated pins and vice versa
    Returns a list of the violating pins
    SCCS Info: @(#) CCFcheckBubbles.il 08/07/17.18:05:43 1.1
    procedure(CCFcheckBubbles(@key (cvId geGetEditCellView()) (suffix "N"))
      let((negatedPinPattern negatedPin anyBubbles
            (badPins makeTable('badPins t)))
        negatedPinPattern=pcreCompile(strcat(suffix "$"))
        foreach(term cvId~>terminals
          negatedPin=pcreExecute(negatedPinPattern term~>name)
          foreach(pin term~>pins
            foreach(pinFig pin~>figs
              ; Find lines on the device layer which overlap the pin
              foreach(shape dbGetOverlaps(cvId pinFig~>bBox "device" 0)
                ; This (destructuringBind) is a convenient way of accessing
                ; the numbers in a bounding box
                destructuringBind(((llx lly) (urx ury)) pinFig~>bBox
                  when(shape~>objType=="line"
                    ; just pick first and last point, which is probably overkill
                    ; as most likely this is just the leg of the devicee
                    anyBubbles=nil
                    foreach(point cons(car(shape~>points) last(shape~>points))
                      destructuringBind((x y) point
                        ; If the point is not within the pin box (i.e. the other
                        ; end) then check if it overlaps an ellipse
                        unless(x>=llx && x<=urx && y>=lly && y<=ury
                          anyBubbles=exists(nextShape
                            dbGetOverlaps(cvId list(point point) "device" 0)
                            nextShape~>objType=="ellipse"
                    ; If the pin ends with the negated suffix and doesn't have
                    ; a bubble, or isn't negated and does have a bubble store
                    ; this in the table
                    when(negatedPin && !anyBubbles || !negatedPin && anyBubbles
                      badPins[term~>name]=t
        ; Return the list of pin names which break the rules
        badPins~>?
  • HDar
    Thanks a lot for the example script. It helped a lot.
    Himanshu
