  3. Regular expression replace with backslash
  • Views 19897
greatqs
greatqs over 9 years ago
Objective is to change string like below
"XYZ:DGND" into "\XYZ\:DGND"
where XYZ represents a multibit digits (e.g. XYZ = 642) and DGND can be some other net name
I tried below and it doesn't work. Anyone can help?
pcreReplace(pcreCompile("([0-9]*)") "642:DVDD" "\\\\1" 1)
"\\1:DVDD"
pcreReplace(pcreCompile("([0-9]*)") "642:DVDD" "\\\\1\\" 1)
"\\1"
    You've not got enough backslashes (believe it or not)! You'd need this:
    pat=pcreCompile("(\\d+)")
    thing="642:DVDD"
    pcreReplace(pat thing "\\\\\\1\\\\" 1)
    The first pattern is equivalent to yours. The reason why you need so many backslashes is because backslash has meaning in SKILL strings and in regular expressions. To get a regular expression escape, you need to have two backslashes. If you really want a backslash in the regular expression, you'll need four. The pattern recall would therefore be \\1 (you really want "\1" in the string, so you have to escape it for SKILL), and then four backslashes either side of that.
  • greatqs
    Andrew,
    Thanks for the explanation.
