  3. Issue in coping the schematic using ocean script
  • Views 15341
conrel
conrel over 9 years ago
i have written two scripts in skill, one is trying to make the multiple copies of symbol in new schematic design and 2nd one that will call the layout (of same design whose symbol we are using) multiple times to form the layout of our new design.
Then I passed my design for DRC and LVS check, there is no any error coming but while passing through PEX check, i am facing some problems.
1. In PEX window, if i choose "Use names from:Schematic" then in PEX error is coming(Names in schematic and layout both are same). and If i choose "Use names from:Layout" . Then error is not coming,a warning is coming which i am not able to understand.
I am scratching my head from last two days but didn't get any solution of this. I would really appreciate if you could Help. Attaching my commands and screenshot of output window.
For layout copying, using commands:
for(i 0 row-1
for(j 0 col-1
loc_x = 2*ring_wd + 2*ring_sp + cell_width*j
loc_y = 2*ring_wd + 2*ring_sp + cell_height*i
sprintf(cellInst "cellinst_%d_%d" i j)
sprintf(cell_Name "cell_Name_%d_%d" i j)
cell_Name = dbOpenCellViewByType(sramLib_
Name cellCV_Name "layout" "maskLayout" "r")
cellInst = dbCreateInst(SRAM_cv cell_Name cellInst list(loc_x, loc_y) orientation)
For Schematic copying, i am using these commands:
for(i 0 col-1
for(j 0 row-1
sprintf(cellCV_Name "cell_CV_Name_%d_%d" i j)
cellCV_Name =  dbOpenCellViewByType(design_Lib_Name cell_Name "symbol" "schematicSymbol" "r")
cellInstId= dbCreateInst(new_design cellCV_Name cellInst list(3.5*i, 3.5*j) orientation)
    Given that the error (or warning) is coming from a Mentor tool rather than a Cadence tool, you might be better off asking the question in a Mentor forum or via your Mentor support channel.
    The code you've used to copy seems reasonable (it's hard to tell because I'm presuming there must be something else to connect things up?). There's a line in both pieces of code which is redundant (the second sprintf doesn't seem to be necessary) but that wouldn't affect what you're doing here, I'd have thought.
    Oh, and a bit of terminology - this isn't an "ocean" script. OCEAN is the set of functions related to controlling analog simulation and processing the results; it's not a language in itself (SKILL is the language) - and what you're doing here is nothing to do with setting up an analog simulation or post-processing. So it's just SKILL... (sorry to be pedantic!)
