  3. Selecting shapes that enclose text of a certain value, for...
  • Views 16216
Selecting shapes that enclose text of a certain value, for use by ABE functions
caver456
caver456 over 9 years ago
FETs in our pcell library include a label in the middle of the gate whose text is equal to the device type name, i.e. "nchn5".
I would like to select all gates of a certain device type, i.e. all gates that enclose a label with text=="nchn5", and use those gates in some existing Advanced Boolean Engine code.
Pseudo-code would look something like this, if the above could be boiled down to a Calibre-style "with text" command:
pgate=abeLayerFromCellView("pgate")
pgate_nchn5=pgate with text "nchn5"
abeLayerSize(pgate_nchn5 pgate_nchn5_big 1.0)
What's the best way to accomplish this?
My first thought was to draw a little dummy rectangle around each nchn5 label, so we would have a shape to use in the abe commands, from where it would be easy to come up with the pgate_nchn5 layer, so:
I can select said labels from any hierarchy level with this code:
nchn5_labels=leSearchHierarchy(cv cv->bBox 30 "label" list(list("layer" "==" list("pgate" "drawing")) list("text" "==" "nchn5")))
But, the returned objects may be from various levels of hierarchy, so their ->xy is not necessarily relative to the top level, and the return value of leSearchHierarchy does not give the full hierarchical path of each object, from which you could concatenate the transforms.
From here, it seems like there are a few options:
1) find out the way to return the ->xy of each label in top-level-coordinates
or
2) find some other way to get to the same goal, i.e. a command  such as abeCreateBoxAtLabelOrigin("nchn5" 0.01) which would create an in-memory box on an abe layer without having to modify the layout
Any thoughts?
    Probably you'd have to do something like a dbShapeQuery or a dbGetOverlaps to find the paths to the objects in that particular lpp, filter it to just find the labels, and then you can use the dbGetHierPathTransform to find the overall transformation needed to transform the xy of the leaf label to the top level coordinate system. This might be useful to find the leaf shape so you can determine whether it's a label or not:
    *                 abGetHierPathShape (overlap)                 *
    *             Find the leaf shape from an overlap              *
    (defun abGetHierPathShape (overlap)
      (if (listp overlap)
        (abGetHierPathShape (cadr overlap))
        overlap))
    You could then either construct small rectangles as you suggested in an abeLayer object and then use abeLayerTouch or similar to select the gate shapes you want, or you could use dbShapeQuery for each transformed xy to find the gate shapes you want, transform these to the top level, and add to your abeLayer and then grow them - depends what you're trying to do and how many shapes there are as to what is the most efficient.
    Of course, it would be nice if there was an abe function to deal with labels in some interesting way - but there isn't (not sure how easy it would be since that would probably require new data structures to deal with labels).
  • caver456
    Turns out that the returned objects from leSearchHier are not unique - if the label is in a pcell, and you have three different placements of that pcell, at various levels of the hierarchy, then you will get three identical db: id objects. So you'd have to follow the database path in a different manner, which may be what you were suggesting? Anyway, with discretion winning out for now since this scenario won't be used much, I just went with a requirement for the user to draw a certain shape wherever the label would occur. Label recognition can happen at a later date. Thanks for the leads.
