  3. Regarding point selection
  • Views 15570
skillEater
skillEater over 9 years ago
Is there any way to select point in layout by using function in virtuoso.
For your clarification it may be the reverse function of enterPoint.
Ganesh.
  • skillUser
    skillUser over 9 years ago
    Hi Ganesh,
    Well, there is geSelectFig(), geSelectFigNoFilter() [ignores any selection filter in place], geGetPotentialSelection() and a few other functions to either select a figure (shape, instance, via ...) or find out what might be selectable at a location. Also there are functions such as dbGetOverlaps(), dbProduceOverlap(), and dbProduceOverlapInst() as well as the db.*Query family of functions to 'look' at a point to see what is under it (selectable or not).
    Hopefully these will get you started?
    Best regards,
    Lawrence.
  • skillEater
    Thanks for the above information Lawrence.
    Ganesh
    It's not that clear what you want - perhaps you want geSelectPoint() or geAddSelectPoint()?
