  3. Callback function for Library Manager Menu Item
  • Views 17288
mschw
mschw over 9 years ago
i want to add a new menu item to the Library manager which prints the library name /cell name /... in the CIW. I added to the cdsLibMgr.il file the following piece of code
(lmgrCreateMenuItem "myLmgrMenuItem" "simple"
                    '(("label" "Print in CIW")
                      ("callback" ("myLmgrMenuItemCallback"))
(lmgrInsertMenuItems "copySimpleButton" "CV" '("myLmgrMenuItem"))
The callback function is
procedure(myLmgrMenuItemCallback(str1 str2 str3 str4 str5 str6)
printf("%s %s %s %s %s %s" str1 str2 str3 str4 str5 str6)
If I select an arbitrary cell in the library manager and after pressing the right mouse button and clicking on the new entry "Print to CIW" nothing happens. But if I subsequently select another entry in this menu (e.g. "Properties" or "Open ..") then the correct information is printed in the ciw.
I use IC6.1.7-64b.500.5
Many thanks in advance,
mschw
    You need to add a "\n" to the end of the first argument of the printf - i.e. printf("%s %s %s %s %s %s\n" str1 str2 str3 str4 str5 str6) - so that it prints a carriage return. Then it will print immediately - otherwise it's being buffered until there's enough output or a carriage return appears...
  • mschw
    Dear Andrew,
    thanks a lot. it works now.
    Best regards,
    mschw
