  3. Running skill function before simulation to prevent its...
  • Views 17411
Running skill function before simulation to prevent its start
aakhavan
aakhavan over 9 years ago
I'd like to set up my environment to run a skill function just before a simulation starts to check system load. If the load is too high, it will display a message and prevent the simulation from running. I need to support both ADE-L and ADE-XL. What's the best way to do this?
From what I've found in the documentation, I can add a pre-simulation callback in ADE-XL using the axl* functions and signals/triggers. However, it does not appear that the callback can prevent the simulation from running.
For ADE-L, I've not been able to find a similar pre-sim callback. I could either overwrite all of the toolbar buttons and menu items, or overwrite the run functions. It seems that the UI elements are all re-generated and the callbacks for them changed every time the simulator changes, which poses a problem.
I can overwrite all of the run simulation functions, but I'd have to do so for every simulator (assuming they don't get re-defined on simulator changes).
    For ADE XL (and Explorer and Assembler) you'd use a preRun trigger (specified with axlSessionConnect). In the preRun trigger, you need to set this env var - it's not based on the return value of the preRun trigger (unfortunately) - so you need to use this as a semaphore to indicate that you want to halt the run:
    ; This is a semaphore to indicate that the simulation should not
    ; proceed
    envSetVal("adexl.simulation" "haltCurrentRunAfterPreRunTrigger" 'boolean t)
    For ADE L, you'd change the flowchart step for (say) asiStartSimulator:
    procedure(CCFstartSimPreFunc(session)
      let(((status t))
        when(getd('CCFexistingSpectrePreFunc)
          status=CCFexistingSpectrePreFunc(session)
        when(status
          ; do your determination on whether to proceed here and return t (to start) or nil (to not start)
          ; the line below is just to allow me to experiment with setting CCFRETURNVALUE globally to t or nil to
          ; control whether sim starts or not
          if(boundp('CCFRETURNVALUE) then CCFRETURNVALUE else t)
    tool=asiGetTool('spectre)
    flow=asiGetFlowchart(tool)
    step=asiGetFlowchartStep(flow 'asiStartSimulator)
    unless(step->preFunc=='CCFstartSimPreFunc
      putd('CCFexistingSpectrePreFunc step->preFunc)
    asiChangeFlowchartStep(flow ?name 'asiStartSimulator ?preFunc 'CCFstartSimPreFunc)
    Hope that helps!
  • aakhavan
    That worked great. Thank you!
  • aakhavan
    Andrew,
    I'm now observing some strange behavior with this setup in ADE-XL only (see skill below).
    When some_condition evaluates true, it appears to work properly, and the simulation proceeds.
    When some_condition evaluates false, however, the AppDBox shows up twice. The first time happens when I click the run button, as expected. The second time comes roughly after the job starts. I also see a few warnings about context cache and context manager. Clicking no on the form causes the sim to stop, as desired, though I suspect its not behaving properly as I get an "Error occurred while simulating the design". The goal here is to display a form to the user that lets them decide whether or not to run the simulations.
    Interestingly, another machine exhibits different behavior: it stops cleanly if I click no on the form, but when I click yes, it runs all the jobs with no errors, but never starts the simulator...
    It seems like there is some other issue going on, but as far as the pre-sim function goes, am I doing something obviously incorrect?
    Thank you!
    procedure(startSimPreFuncXL(session setupdb mode testName)
    let((formResult)
    if(some_condition then
    envSetVal("adexl.simulation" "haltCurrentRunAfterPreRunTrigger" 'boolean nil)
    else
    formResult = hiDisplayAppDBox(...)
    envSetVal("adexl.simulation" "haltCurrentRunAfterPreRunTrigger" 'boolean not(formResult))
    ) ;if
    );let
    );proc
    procedure(addSimPreFuncXL(session)
    axlSessionConnect(session "preRun" 'startSimPreFuncXL)
    t
    axlSessionRegisterCreationCallback('addSimPreFuncXL)
