  3. polygon subtraction
  • Subscribers 150
  • Views 18400
polygon subtraction
drdanmc
drdanmc over 9 years ago
I was working on some skill code to generate a logo for a sheet symbol and ended up in a spot where I need to subtract two polygons.  My preference is to operate on the lists  of points that define the two polygons:
points1 = list(0:0 10:0 10:10 0:10 0:0)
points2=list(2:2 8:2 8:8 2:8 2:2)
points3 = myPolyptsSub(points1, points2) ;; not sure how to implement
fig=dbCreatePolygon(cv, my_lpp, points3)
alternatively, I could live with
fig1 = dbCreatePolygon(cv, my_lpp, points1)
fig2 = dbCreatePolygon(cv, my_lpp, points2)
fig3 = dbLayerAndNot(cv, my_lpp, list(fig1), list(fig2))
dbDeleteObject(fig1)
dbDeleteObject(fig2)
;; is there a db* function to merge the geometries that come back or only the leMergeShapes() function
;; in fig3 (which should be a list)
but it would be nice to be able to work directly with the points.
The reason I'm interested in working directly with points is I have some code that takes an SVG path specification string and turns it into polygon points but some cases may involve an outside shape with some cutouts.  My real case is more complicated than just a square cut out of a square.  Think polygons with hundreds of points.
Thanks for any suggestions.
-Dan
  • mschw
    mschw over 9 years ago
    Dear Dan,
    you could use dbLayerXor(cv, mylayerName, list(fig1), list(fig2)).
    Best regards,
    mschw
  • skillUser
    skillUser over 9 years ago
    Based on the other response and your need to operation on the points directly you could look at the dbPointArrayXXX functions like dbPointArrayXor(). Hopefully this will help.
    Best regards, Lawrence.
  • drdanmc
    Thanks! I had missed the dbPointArray* functions. I find it interesting that those functions need a cellview ID even though they don't actually modify the cellview. I would have thought those would strictly work on points.
    but this seems to work
    points3 = dbPointArrayXor(cv list(points1) list(points2))
    foreach(p points3
    dbCreatePolygon(cv, my_lpp, p)
    -Dan
    Dan,
    I think it's needed to (at least) convert from user units to the underlying database units (so the shapes have the right resolution). May be for other things too - but that's certainly needed.
