  3. Number of instaces in schematic.
  • Subscribers 148
  • Views 6505
Serjik
Serjik over 9 years ago
Hi all.
I've got a cell, which consists of many cells (some of them are repeated). For example there are 10 instA and 15 instB (they are all separate cells). How can I delete a certain number of empty cells, for example 4 instA and 3 instB.
Sergey.
  • skillUser
    skillUser over 9 years ago
    Hi Sergey,
    Your question does not really contain enough information to even start an answer. What type of cell, layout or schematic for instance? What do you mean by an empty cell, and if a cell was 'empty' (e.g. the cell that was used for instA) wouldn't all instances be the same (i.e. all 10 of instA not just 4). There are too many questions about your question to offer any suggestions, please clarify.
    Lawrence.
  • Serjik
    Hi, Lawrence.
    I'm talking about schematic. The cells are not empty, they are separate. For example, 10 the same pmos transistors and 15 the same nmos transistors. After that I read from the file information about how many cells of what type I need to delete (how to read from the file is clearly). The question is how to delete a certain number of identical cells.
    Sergey.
    Sergey,
    It's a strange (and confusing) request, but I'm guessing something like (the variables theLibName and theCellName are to indicate what it is you're trying to delete). cv is the cellView id you're working on.
    instHeader=car(exists(instH cv~>instHeaders instH~>libName==theLibName && instH~>cellName==theCellName))
    numToDelete=4
    instances=instHeader~>instances
    while(numToDelete>0 && instances
      numToDelete--
      dbDeleteObject(car(instances))
      instances=cdr(instances)
  • Serjik
    Thanks Andrew, that's exactly what I need.
    Sergey.
