  3. Remove and edit prop from pin / net in schematic
  • Views 17802
nosaj
nosaj over 9 years ago
I'm looking for the skill commands to remove and edit nlAction property from pins in schematic and netType property from nets.  They are located in :
inst~>pin~>term~>prop
cv~>nets~>prop
geGetSelSet()~>pin~>term~>prop~>??
(((db:0x1e0b72a3 cellView db:0x1e0b769a objType "prop"
        prop nil enum nil name
        "nlAction" object db:0x1e0b759c range nil
        value "ignore" valueType "string" assocTextDisplays
        nil )))
cv~>nets~>prop~>??
(nil nil (
    (db:0x1e0b7045 cellView db:0x1e0b721a objType "prop"
    "netType" object db:0x1e0b471f range nil
    value "supply0" valueType "string" assocTextDisplays
    nil
) nil nil
    You would need to iterate over the nets or terminals in the schematic, and then either do a dbFindProp to find the property object called nlAction on each and then call dbDeleteObject() to delete that property object, or iterate over the nets/terminals and then call dbDeletePropByName() to delete the nlAction property.
  • nosaj
    dbFindProp on inst and net return nil but nlAction and netType are there. What am I missing here?
    PIN :
    dbFindProp(inst "nlAction")
    nil
    inst~>pin~>term~>prop~>??
    ((db:0x1e0b7043 cellView db:0x1e0b721a objType "prop"
    "nlAction" object db:0x1e0b6ea2 range nil
    nil
    NET :
    net
    (db:0x1e0b471f)
    net
    (db:0x1e0b471f)
    dbFindProp(car(net) "nlAction")
    nil
  • nosaj
    i figured out how to delete the prop from pin. Still not sure how to delete prop from net.
  • nosaj
    figured that out as well, thanks
