  3. $sscanf in verilog-A
  • Views 17903
AishwaryaP
AishwaryaP over 9 years ago
Following is my verilog A code. I am tying to append an integer to string and assign it to a string using $sscanf.
string filename;
string ext;
integer file_num;
analog begin
@(initial_step) begin
file_num=1;
ext="csv";
filename=$sscanf("%d.%s",file_num,ext);
end
end
I get error while saving the file. Error: Missing arguments.
 ERROR : "filename=$sscanf("%d.%s",file_num,ext)<<--?
Encountered invalid type conversion for `filename' (`integer' to `string'). Check the validity of conversion and try again.
I also tried string concatenation
filename={file_num,ext};
For the above statement file_num is defined as string and file_num="1" is the initialization statement. ext is initialized with ".csv". I get syntax error.
Please let me know what is wrong with my code.
I am using virtuoso 6.1.6. mmsim 14.1.0.
