  3. Can't start command si -batch under skill
  • Views 3996
MedAn
MedAn over 9 years ago
Hi all!
I write a small script to generate si.env file and start procedure for cdlOut.
But process finished without any error and without any  results. If I try to start the same command with the same si.env file under 'bash' - all works fine.
I try to start command: "si -batch -command netlist" under ipcBeginProcess and under system but result the same.
Could you pls. tell me, what I did wrong?
There is my small code:
procedure(runCDLout(lib cell)
prog(
(id)
;;remove lock file
when(isFile(strcat(getWorkingDir() "/.running"))
system(sprintf(nil "rm %s/.running" getWorkingDir()) );
;;create si.env file
siEnvPrep(lib cell);
id = ipcBeginProcess("si -batch -command netlist");
ipcWait(id);
;system("si -batch -command netlist > si.log");
);end prog
);irunCDLout
procedure(siEnvPrep(lib cell)
prog(
(outFile runDir)
runDir = strcat(getWorkingDir() "/act_generator/cdl");
outFile = outfile("./si.env" "w");
fprintf(outFile sprintf(nil "simLibName = \"%s\" \nsimCellName = \"%s\" \nsimViewName = \"schematic\" \n
simSimulator = \"auCdl\" \n
simNotIncremental = nil\n
simReNetlistAll = 't\n
simViewList = '(\"auCdl\" \"schematic\" \"symbol\")\n
simStopList = '(\"auCdl\")\n
hnlNetlistFileName = \"%s\" \n
resistorModel = \"\"\n
shortRES = 2000.0 \n
preserveRES = 't \n
checkRESVAL = 't \n
checkRESSIZE = 'nil \n
preserveCAP = 't \n
checkCAPVAL = 't \n
checkCAPAREA = 'nil \n
preserveDIO = 't \n
checkDIOAREA = 't \n
checkDIOPERI = 't \n
checkCAPPERI = 'nil \n
simPrintInhConnAttributes = 'nil \n
checkScale = \"meter\" \n
checkLDD = 'nil \n
pinMAP = 'nil \n
shrinkFACTOR = 0.0 \n
globalPowerSig = \"\" \n
globalGndSig = \"\" \n
displayPININFO = 't \n
preserveALL = 't \n
setEQUIV = \"\" \n
incFILE = \"\" \n
auCdlDefNetlistProc = \"ansCdlSubcktCall\"" lib cell strcat(cell ".cdl")
);end sprintf
);end fprintf
close(outFile);
in log file I have only this:
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
    This code worked for me... (from a very quick test).
  • MedAn
    Hi Andrew!
    I'm so sorry, I don;t know what happened., but after that I posted my question this code working for me also.
    But could you pls. tell me, way it takes a lot of time, form my side about 1 minute/ but under bash or through ciw->export it takes about 20-30 sec?
    I have no idea why it should take different amounts of times by running it different ways. Probably this is something you should explore via customer support.
  • MedAn
    Hi Andrew!
    Ok, thx.
