  3. dbProduceOverlap when dealing with "simple" mosaics
  • Views 2662
rfontaine
rfontaine over 9 years ago
Below is a snipet of code I've used in IC5 to raise certain layers that fall within a specific bBox to my top level.I'm finding now that in IC6 (OA)  mosaics are apparently handled differently. Can anyone share some help on raising shapes (including mosaics) to the top cell in IC6.
   xFormData = foreach( mapcar shapeSpec removeDups(dbProduceOverlap(cv searchArea depth lpp))
      foreach( mapcar spec flattenList(shapeSpec)
        ;printf("\n spec objType is %L \n" spec~>objType)
    cond(
          ( spec~>objType == "inst"
            ; x y rot rows columns dX dY
            list( xCoord(spec~>xy) yCoord(spec~>xy) cadr(spec~>transform) 1 1 0 0 )
          ( spec~>objType == "stdVia"
            list( xCoord(spec~>origin) yCoord(spec~>origin) spec~>orient 1 1 0 0 )
          ( spec~>objType == "mosaic"
            m=spec
            list( xCoord(m~>xy) yCoord(m~>xy) car(m~>tileArray) m~>rows m~>columns m~>uX m~>uY )
          ( t   ; a shape - last element
            spec
        );end cond
      );end foreach
    );end foreach
  • dmay
    dmay over 9 years ago
    There are several changes in how mosaics are stored in OA as compared with CDB. There should be some OA compatibility document that describes all of this in detail. First of all, in CDB there were two objects, a mosaic and a mosaicInst. In OA, there is just the mosaic object. Also, in OA, rotations are handled differently. In CDB, when a mosaic is rotated 90, the number of rows and columns, and the uX and uY are transposed so that the values represent what you see on the screen. In OA, these values don't change at all for any rotation.
    When we were working in both CDB and OA for many years, I wrote a utility to return mosaic information in a disembodied property list that looked the same for both OA and CDB. This allowed us to write code compatible with both versions without needing conditionals all over our code. I've included it below for your convenience.
    Derek
    procedure(mydbGetMosaicInfo(m)
      prog((oaFlag columns uX uY orient rows xy mInst name)
        case(m~>objType
            ("inst"
               ;not a mosaic
               return(nil)
            ("mosaicInst" ;OA compliant
                ;cdb mosaicInst
                mInst=m
                m=m~>mosaic
            ("mosaic"
                if(car(m~>instanceList)~>objType=="mosaic" then
                    ;oa mosaic
                    oaFlag=t
                else
                    ;cdb mosaic
                    mInst=car(m~>instanceList)
                    t
            (t
               ;not a mosaic
               return(nil)
        if(oaFlag then
            orient=car(m~>tileArray)
            xy=m~>xy
            if(member(orient list("R0" "R180" "MX" "MY")) then
                rows=m~>rows
                columns=m~>columns
            else
                rows=m~>columns
                columns=m~>rows
            case(orient
                ("R0"       uX=m~>uX    uY=m~>uY)       ;OA compliant
                ("R90"      uX=-(m~>uY) uY=m~>uX)       ;OA compliant
                ("R180"     uX=-(m~>uX) uY=-(m~>uY))    ;OA compliant
                ("R270"     uX=m~>uY    uY=-(m~>uX))    ;OA compliant
                ("MX"       uX=m~>uX    uY=-(m~>uY))    ;OA compliant
                ("MXR90"    uX=m~>uY    uY=m~>uX)       ;OA compliant
                ("MY"       uX=-(m~>uX) uY=m~>uY)       ;OA compliant
                ("MYR90"    uX=-(m~>uY) uY=-(m~>uX))    ;OA compliant
            name=m~>name
            return(list(nil 'orient orient 'xy xy 'uX uX 'uY uY 'rows rows 'columns columns 'oa t 'mosaic m 'master m~>master 'mosaicName name
                            'libName m~>libName 'cellName m~>cellName 'viewName m~>viewName 'name name 'mosaicInst m))  ;OA compliant
        else
            xy=m~>xy
            uX=m~>uX    ;OA compliant
            uY=m~>uY    ;OA compliant
            rows=m~>rows
            columns=m~>columns
            name=car(m~>instanceList~>name) ;OA compliant
            return(list(nil 'orient orient 'xy xy 'uX uX 'uY uY 'rows rows 'columns columns 'oa nil 'mosaic m 'master mInst~>master 'mosaicName m~>name
                            'libName mInst~>libName 'cellName mInst~>cellName 'viewName mInst~>viewName 'name name 'mosaicInst mInst))  ;OA compliant
      ) ;let
    ) ;proc
    Another example of the difference in handling mosaics in CDB and OA can be found in solution 11328674
